HP E27 G5 27" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor
Quicklinx: H9N6WS00 Mfr#: 6N4E2E9#ABU
Hurry, only 2 left in stock!
£215.00 ex VAT
£258.00 inc VAT
Intentionally crafted to deliver crisp visuals, personalized comfort, and true flexibility, the HP E27 G5 FHD Monitor redefines comfort, so there's nothing between you and your best. Stylishly designed with the planet in mind, this display is the perfect fit for both the office and home.
  • Ergonomic Setup Guide
    Achieve all-day comfort when you apply the best practices from the Ergonomic Setup Guide.
  • Enhanced Viewing Comfort with HP Eye Ease
    Always-on, built-in, low-blue light filter that reduces blue light without the yellow color shift now enhanced with a 75Hz refresh rate.
  • IPS Panel
    No matter where you stand, IPS technology ensures image accuracy and consistency across wide, 178-degree horizontal and vertical viewing angles.
  • 99% sRGB Color Space
    Enjoy what you see on screen with 99% sRGB color space. This display provides ideal color reproduction for vibrant images and videos.
  • Endless Adjustability
    Work effortlessly with 4-way ergonomics that help keep your neck, shoulders, and back comfortable throughout the day. Customize pivot, tilt, 150 mm height adjust, and swivel settings to fit you, your desk, and your needs.
  • More Ports. More Flexibility
    More ports means more capabilities. With an HDMI, DisplayPort , USB-B, and 4 USB-A 3.2 ports, you can connect multiple devices like a headset and webcam.
HP E27 G5 - E-Series - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class D
Energy Consumption per Year
17 kWh
Power Consumption (On mode)
17 W
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.31 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Colour Support
16.7 million colours (8-bit)
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Haze 25%, anti-glare 3H hardness
Voltage
AC 100-240 V (50/60 Hz)
Black, black and silver (stand)
61.2 cm x 22.7 cm x 54.6 cm
6.96 kg
English / United Kingdom
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
VCCI, BSMI, GS, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, PSE Mark, cTUVus, E-Standby, KC, CECP, CEL, EAC, ISC, SEPA, BIS, ICE, NRCS, Ukraine, UAE, Australian-New Zealand MEPS, Vietnam MEPS, TGM, Energy Star, TCO Certified Edge
3-year warranty
Bundled Services
HP 5 years Next Business Day Onsite Hardware Support for Standard Monitors
Display Type
Energy Class
Class D
17 kWh
Diagonal Size
27"
Built-in Devices
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.31 mm
Pixel Per Inch
82
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 85 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
Edge-lit LED
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Dutch, Japanese
On-screen Digital Controls, Low Blue Light Mode, Flicker Free technology, 3 Side Borderless Design, 8-bit(6-bit + FRC) Colour Depth, HP Eye Ease
61.2 cm x 22.7 cm x 54.6 cm - with stand
6.96 kg
DisplayPort 1.2 (HDCP) , HDMI (HDCP) , USB-B , 3 x USB 3.2 Gen 1 (Type A) , USB 3.2 Gen 1 (Type A (power only))
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x HDMI cable - 1.8 m , 1 x DisplayPort 1.2 cable - 1.8 m , 1 x USB-B to USB-A cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
17 W
17 kWh/1000h
Power Consumption (Typical)
30 Watt
Power Consumption (Max)
50 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
HP Display Center
Dimensions & Weight Details
With stand - width: 61.2 cm - depth: 22.7 cm - height: 54.6 cm - weight: 6.96 kg , Without stand - width: 61.17 cm - depth: 4.64 cm - height: 36.33 cm - weight: 4.83 kg
Shipping Width
69.9 cm
Shipping Depth
16 cm
Shipping Height
44.6 cm
Shipping Weight
10.88 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
Bundled Services
5 °C
35 °C
20 - 80% (non-condensing)
Brand: HP
