HP E27 G4 27" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: GPFPWS00 Mfr#: 9VG71AA#ABU
Work comfortably and stay focused with the optimized ergonomics and Full HD resolution of the HP E27 G4 FHD Monitor with HP Eye Ease that is designed around you. Make life easy for IT with remote manageability.
  • Experience simple, convenient connectivity
    Connect to your most frequently-used devices with VGA, HDMI, and DisplayPort . Add up to four of your USB accessories right at the monitor with the integrated USB 3.2 hub.
  • Find your comfort zone
    Work comfortably with adjustable tilt, height, and swivel settings. Use pivot rotation to conveniently customize portrait or landscape views on multiple monitors.
  • Responsibly made
    Energy efficiency is built into every ENERGY STAR certified, EPEAT 2020 registered, and low halogen display. We go one step further with 100% recyclable packaging that's easily accepted by recycling facilities.
  • Take your PC off the desk
    Create an efficient, compact, solution when you mount your HP Desktop Mini PC directly on the column stand using the optional HP B300 PC Mounting Bracket.
  • Personalize and help protect your monitor
    Customize your monitor and help deter its theft with easy, intuitive HP Display Center software that lets you tailor your settings, partition screens, and even dim the screen if your monitor is disconnected without approval-all through the host PC.
  • Complete the picture
    Customize a total solution with options5 like the HP S101 Speaker Bar, which attaches easily to the lower bezel to add stereo audio on the monitor.
HP E27 G4 - E-Series - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/360056
Energy Class
Class D
Power Consumption (On mode)
16.9 W
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare 3H hardness
Voltage
AC 230V (50/60 Hz)
61.17 cm x 21.6 cm x 53.52 cm
6.9 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Carbon Footprint
210 kg carbon emissions
TUV, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, CEC, KC, CECP, CEL, EAC, ISC, SEPA, BIS, low halogen, ICE, TUV LBL, Australian-New Zealand MEPS, Vietnam MEPS, TGM
3-year warranty
Bundled Services
HP 5 years Next Business Day Onsite Hardware Support for Standard Monitors
Display Type
Energy Class
Class D
Diagonal Size
27"
Built-in Devices
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Pixel Per Inch
82
Brightness
250 cd/m²
Contrast Ratio
Response Time
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
On-screen Digital Controls, Low Blue Light Mode, Flicker Free technology, 3-sided micro-edge, 6-bit + FRC Color Depth, HP Eye Ease
61.17 cm x 21.6 cm x 53.52 cm - with stand
6.9 kg
DisplayPort 1.2 , HDMI , VGA , 4 x USB 3.2 Gen 1 downstream , USB (Type B)
Mechanical
Tilt Angle
-5/+23
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x HDMI cable , 1 x DisplayPort 1.2 cable , 1 x USB-B to USB-A cable
Security Slot Type
Kensington security slot
Input Voltage
AC 230V (50/60 Hz)
16.9 W
16.9 kWh/1000h
Power Consumption (Typical)
22 watt
Power Consumption Stand by
0.5 watt
Dimensions & Weight Details
With stand - width: 61.17 cm - depth: 21.6 cm - height: 53.52 cm - weight: 6.9 kg , Without stand - width: 61.17 cm - depth: 4.7 cm - height: 36.36 cm
Shipping Width
69.5 cm
Shipping Depth
44.4 cm
Shipping Height
22.5 cm
Shipping Weight
10.4 kg
Sustainability Information
ENERGY STAR Certified
Carbon Footprint
Manufacturing (kg CO2e)
136
Logistics (kg CO2e)
3
Use (kg CO2e)
64
EOL (kg CO2e)
4
Limited warranty - parts and labour - 3 years
Bundled Services
5 °C
35 °C
20 - 80% (non-condensing)
GPFP HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.36
GPFP HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £32.96
GPFP HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.59
