Work comfortably and stay focused with the optimized ergonomics and Full HD resolution of the HP E27 G4 FHD Monitor with HP Eye Ease that is designed around you. Make life easy for IT with remote manageability.
                Experience simple, convenient connectivityConnect to your most frequently-used devices with VGA, HDMI, and DisplayPort . Add up to four of your USB accessories right at the monitor with the integrated USB 3.2 hub.
                Find your comfort zoneWork comfortably with adjustable tilt, height, and swivel settings. Use pivot rotation to conveniently customize portrait or landscape views on multiple monitors.
                Responsibly madeEnergy efficiency is built into every ENERGY STAR certified, EPEAT 2020 registered, and low halogen display. We go one step further with 100% recyclable packaging that's easily accepted by recycling facilities.
                Take your PC off the deskCreate an efficient, compact, solution when you mount your HP Desktop Mini PC directly on the column stand using the optional HP B300 PC Mounting Bracket.
                Personalize and help protect your monitorCustomize your monitor and help deter its theft with easy, intuitive HP Display Center software that lets you tailor your settings, partition screens, and even dim the screen if your monitor is disconnected without approval-all through the host PC.
                Complete the pictureCustomize a total solution with options5 like the HP S101 Speaker Bar, which attaches easily to the lower bezel to add stereo audio on the monitor.
- HP E27 G4 - E-Series - LED monitor - Full HD (1080p) - 27" - Smart Buy
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/360056
- Energy Class
- Class D
- Power Consumption (On mode)
- 16.9 W
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey with overdrive)
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare 3H hardness
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 61.17 cm x 21.6 cm x 53.52 cm
- 6.9 kg
- Localisation
- English / United Kingdom
- Manufacturer Selling Program
- HP Smart Buy
- Environmental Standards
- ENERGY STAR Qualified
- TUV, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, CEC, KC, CECP, CEL, EAC, ISC, SEPA, BIS, low halogen, ICE, TUV LBL, Australian-New Zealand MEPS, Vietnam MEPS, TGM
- Bundled Services
- HP 5 years Next Business Day Onsite Hardware Support for Standard Monitors
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Pixel Per Inch
- 82
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- On-screen Digital Controls, Low Blue Light Mode, Flicker Free technology, 3-sided micro-edge, 6-bit + FRC Color Depth, HP Eye Ease
- Black
- 61.17 cm x 21.6 cm x 53.52 cm - with stand
- 6.9 kg
- DisplayPort 1.2 , HDMI , VGA , 4 x USB 3.2 Gen 1 downstream , USB (Type B)
Mechanical
- Tilt Angle
- -5/+23
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support
- Cables Included
- 1 x HDMI cable , 1 x DisplayPort 1.2 cable , 1 x USB-B to USB-A cable
- Localisation
- HP Smart Buy
- Security Slot Type
- Kensington security slot
- Input Voltage
- 16.9 W
- Power Consumption SDR (On mode)
- 16.9 kWh/1000h
- Power Consumption (Typical)
- 22 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 61.17 cm - depth: 21.6 cm - height: 53.52 cm - weight: 6.9 kg , Without stand - width: 61.17 cm - depth: 4.7 cm - height: 36.36 cm
- Shipping Width
- 69.5 cm
- Shipping Depth
- 44.4 cm
- Shipping Height
- 22.5 cm
- Shipping Weight
- 10.4 kg
Sustainability Information
- ENERGY STAR Certified
- Bundled Services
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
|  | HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site | In Stock | £22.36 |
|  | HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £32.96 |
|  | HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site | In Stock | £5.93 |
|  | HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor | In Stock | £10.59 |
