Intentionally crafted to deliver crisp visuals and personalized comfort, the HP E24u G5 FHD USB-C Monitor redefines flexibility and power, so there's nothing between you and your best. Stylishly designed with the planet in mind, this display is the perfect fit for both the office and home.
Ergonomic Setup Guide
Achieve all-day comfort when you apply the best practices from the Ergonomic Setup Guide. -
Enhanced Viewing Comfort with HP Eye Ease
HP Eye Ease, an always-on, low-blue light filter, helps keep your eyes comfortable throughout the day by reducing blue light without impacting color-now enhanced with a 75Hz refresh rate. -
IPS Panel
No matter where you stand, IPS technology ensures image accuracy and consistency across wide, 178-degree horizontal and vertical viewing angles. -
Daisy Chain a Second Monitor
Display even more with DisplayPort by daisy chaining a second monitor for the ultimate dual-display setup. -
99% sRGB Color Space
Ideal color reproduction with minimal effort. -
Endless Adjustability
Work effortlessly with 4-way ergonomics that help keep your neck, shoulders, and back comfortable throughout the day. Customize pivot, tilt,150 mm height adjust, and swivel settings to fit you, your desk, and your needs.
- HP E24u G5 - E-Series - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class E
- Power Consumption (On mode)
- 15.6 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 8000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey with overdrive)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Haze 25%, anti-glare 3H hardness
- Voltage
- AC 100-240 V (50/60 Hz)
- Black head, black and silver (stand)
- 53.94 cm x 21.1 cm x 50.7 cm
- 6 kg
- Localisation
- English / United Kingdom
- Works With Chromebook
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
- Carbon Footprint
- 220 kg carbon emissions
- VCCI, BSMI, GS, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, PSE Mark, cTUVus, E-Standby, KC, CECP, CEL, EAC, ISC, CEL Grade 2, SEPA, BIS, low halogen, ICE, NRCS, Ukraine, UAE, Australian-New Zealand MEPS, Vietnam MEPS, TGM, TUV Hardware Low Blue Light Certification, Energy Star, Works With Chromebook (WWCB) certified, Korea MEPS, Ukraine EE
- 3-year warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 86 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- Edge-lit LED
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Dutch, Japanese
- On-screen Digital Controls, Low Blue Light Mode, Flicker Free technology, 3 Side Borderless Design, 8-bit(6-bit + FRC) Colour Depth, HP Eye Ease
- 53.94 cm x 21.1 cm x 50.7 cm - with stand
- 6 kg
- DisplayPort 1.2 (HDCP) , DisplayPort 1.2 output (HDCP) , HDMI (HDCP) , USB-C 3.2 Gen 1 (HDCP, DisplayPort Alt Mode, power up to 65W) , USB-C 3.2 Gen 1 (HDCP, power up to 15W) , 2 x USB 3.2 Gen 1 , USB 3.2 Gen 1 (power only) , LAN (RJ-45)
Mechanical
- Tilt Angle
- -5/+23
- Swivel Angle
- 45
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support
- Cables Included
- 1 x USB-C to USB-C cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 15.6 W
- Power Consumption SDR (On mode)
- 15.6 kWh/1000h
- Power Consumption (Typical)
- 23.5 Watt
- Power Consumption (Max)
- 160 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Display Center, HP Display Manager
- Dimensions & Weight Details
- With stand - width: 53.94 cm - depth: 21.1 cm - height: 50.7 cm - weight: 6 kg , Without stand - width: 53.94 cm - depth: 7.5 cm - height: 32.26 cm
- Shipping Width
- 62.1 cm
- Shipping Depth
- 14 cm
- Shipping Height
- 40 cm
- Shipping Weight
- 8 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Carbon Footprint
- Manufacturing (kg CO2e)
- 154
- Logistics (kg CO2e)
- 2
- Use (kg CO2e)
- 64
- EOL (kg CO2e)
- 3
- Total Carbon w/o Use Phase (kg CO2e)
- 220
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% RH (non-condensing)
HP E24u G5 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor
