HP E24u G5 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: HW49WS00 Mfr#: 6N4D0AA#ABU
£227.30 ex VAT
£272.76 inc VAT
Intentionally crafted to deliver crisp visuals and personalized comfort, the HP E24u G5 FHD USB-C Monitor redefines flexibility and power, so there's nothing between you and your best. Stylishly designed with the planet in mind, this display is the perfect fit for both the office and home.
  • Ergonomic Setup Guide
    Achieve all-day comfort when you apply the best practices from the Ergonomic Setup Guide.
  • Enhanced Viewing Comfort with HP Eye Ease
    HP Eye Ease, an always-on, low-blue light filter, helps keep your eyes comfortable throughout the day by reducing blue light without impacting color-now enhanced with a 75Hz refresh rate.
  • IPS Panel
    No matter where you stand, IPS technology ensures image accuracy and consistency across wide, 178-degree horizontal and vertical viewing angles.
  • Daisy Chain a Second Monitor
    Display even more with DisplayPort by daisy chaining a second monitor for the ultimate dual-display setup.
  • 99% sRGB Color Space
    Ideal color reproduction with minimal effort.
  • Endless Adjustability
    Work effortlessly with 4-way ergonomics that help keep your neck, shoulders, and back comfortable throughout the day. Customize pivot, tilt,150 mm height adjust, and swivel settings to fit you, your desk, and your needs.
HP E24u G5 - E-Series - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class E
Power Consumption (On mode)
15.6 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Haze 25%, anti-glare 3H hardness
Voltage
AC 100-240 V (50/60 Hz)
Black head, black and silver (stand)
53.94 cm x 21.1 cm x 50.7 cm
6 kg
English / United Kingdom
Works With Chromebook
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
Carbon Footprint
220 kg carbon emissions
VCCI, BSMI, GS, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, PSE Mark, cTUVus, E-Standby, KC, CECP, CEL, EAC, ISC, CEL Grade 2, SEPA, BIS, low halogen, ICE, NRCS, Ukraine, UAE, Australian-New Zealand MEPS, Vietnam MEPS, TGM, TUV Hardware Low Blue Light Certification, Energy Star, Works With Chromebook (WWCB) certified, Korea MEPS, Ukraine EE
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.27 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 86 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
Edge-lit LED
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Dutch, Japanese
On-screen Digital Controls, Low Blue Light Mode, Flicker Free technology, 3 Side Borderless Design, 8-bit(6-bit + FRC) Colour Depth, HP Eye Ease
53.94 cm x 21.1 cm x 50.7 cm - with stand
6 kg
DisplayPort 1.2 (HDCP) , DisplayPort 1.2 output (HDCP) , HDMI (HDCP) , USB-C 3.2 Gen 1 (HDCP, DisplayPort Alt Mode, power up to 65W) , USB-C 3.2 Gen 1 (HDCP, power up to 15W) , 2 x USB 3.2 Gen 1 , USB 3.2 Gen 1 (power only) , LAN (RJ-45)
Mechanical
Tilt Angle
-5/+23
Swivel Angle
45
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x USB-C to USB-C cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
15.6 W
15.6 kWh/1000h
Power Consumption (Typical)
23.5 Watt
Power Consumption (Max)
160 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Center, HP Display Manager
Dimensions & Weight Details
With stand - width: 53.94 cm - depth: 21.1 cm - height: 50.7 cm - weight: 6 kg , Without stand - width: 53.94 cm - depth: 7.5 cm - height: 32.26 cm
Shipping Width
62.1 cm
Shipping Depth
14 cm
Shipping Height
40 cm
Shipping Weight
8 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Carbon Footprint
Manufacturing (kg CO2e)
154
Logistics (kg CO2e)
2
Use (kg CO2e)
64
EOL (kg CO2e)
3
Total Carbon w/o Use Phase (kg CO2e)
220
Limited warranty - 3 years
5 °C
35 °C
20 - 80% RH (non-condensing)
Brand: HP
