Enjoy an enhanced viewing experience and make the most of your desk space by charging your PC with a single USB-C cable straight from your monitor. Work comfortably through your day on the HP E24u G4 FHD USB-C Monitor, with optimized ergonomics, HP Eye Ease, and Full HD resolution. Make life easy for IT with remote manageability.
All the ports you need
Connect devices with four USB ports or HDMI and easily daisy-chain additional monitors with DisplayPort . -
Easily mount your Mini
Mount your HP Desktop Mini PC directly on the column stand using the optional HP B300 PC Mounting Bracket for a clutter-free workspace. -
HP Display Center for personalization and protection
Protect your monitor from theft with the intuitive HP Display Center software that lets you personalize your settings, partition screens, and dim the screen if your monitor is disconnected without approval. -
Add optional audio
Customize a total solution with the HP S101 Speaker Bar which attaches easily to the lower bezel to add stereo audio on your monitor. -
Works With Chromebook Certified
The Works With Chromebook badge on a device means it's optimized to work with your Chromebook and other Chrome OS devices. Enjoy a seamless experience across Works With Chromebook certified accessories. -
3-year limited warranty
3-year limited warranty includes technical support, diagnostic services, and hardware replacement.
- HP E24u G4 - E-Series - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class D
- Power Consumption (On mode)
- 13.7 W
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.274 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey with overdrive)
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Sparkling black
- 53.2 cm x 20.7 cm x 49.49 cm
- 6.3 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
- CSA, UL, TUV GS, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, KC, CEL, EAC, ISC, BIS, low halogen, DisplayPort 1.2, ICE, UAE, Australian-New Zealand MEPS, Vietnam MEPS
- 3-year warranty
- Bundled Services
- HP 5 years Next Business Day Onsite Hardware Support for Standard Monitors
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Built-in Devices
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.274 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- HDCP, Low Blue Light Mode, Flicker Free technology, arsenic-free glass, 3-sided micro-edge, 8-bit Colour Depth, USB-C power delivery up to 65 W, HP Eye Ease
- Sparkling black
- 53.2 cm x 20.7 cm x 49.49 cm - with stand
- 6.3 kg
- DisplayPort 1.2 (HDCP) , DisplayPort 1.2 output (HDCP) , HDMI (HDCP) , USB-C (power up to 65W) , 3 x USB 3.2 Gen 1 downstream
Mechanical
- Tilt Angle
- -5/+23
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand
- Cables Included
- 1 x USB-C cable
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 13.7 W
- Power Consumption SDR (On mode)
- 13.7 kWh/1000h
- Power Consumption (Typical)
- 22 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Display Center
- Dimensions & Weight Details
- With stand - width: 53.2 cm - depth: 20.7 cm - height: 49.49 cm - weight: 6.3 kg , Without stand - width: 53.94 cm - depth: 4.7 cm - height: 32.33 cm
- Shipping Width
- 61.1 cm
- Shipping Depth
- 22.3 cm
- Shipping Height
- 39.2 cm
- Shipping Weight
- 8.89 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
- Bundled Services
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site | In Stock | £22.87 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £33.70 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site | In Stock | £6.01 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor | In Stock | £10.83 |
