Brand
HP E24u G4 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: GNXQWS00 Mfr#: 189T0AA#ABU
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, USB-C, HDMI
35 In Stock
£177.61 ex VAT
£213.13 inc VAT
Enjoy an enhanced viewing experience and make the most of your desk space by charging your PC with a single USB-C cable straight from your monitor. Work comfortably through your day on the HP E24u G4 FHD USB-C Monitor, with optimized ergonomics, HP Eye Ease, and Full HD resolution. Make life easy for IT with remote manageability.
  • All the ports you need
    Connect devices with four USB ports or HDMI and easily daisy-chain additional monitors with DisplayPort .
  • Easily mount your Mini
    Mount your HP Desktop Mini PC directly on the column stand using the optional HP B300 PC Mounting Bracket for a clutter-free workspace.
  • HP Display Center for personalization and protection
    Protect your monitor from theft with the intuitive HP Display Center software that lets you personalize your settings, partition screens, and dim the screen if your monitor is disconnected without approval.
  • Add optional audio
    Customize a total solution with the HP S101 Speaker Bar which attaches easily to the lower bezel to add stereo audio on your monitor.
  • Works With Chromebook Certified
    The Works With Chromebook badge on a device means it's optimized to work with your Chromebook and other Chrome OS devices. Enjoy a seamless experience across Works With Chromebook certified accessories.
  • 3-year limited warranty
    3-year limited warranty includes technical support, diagnostic services, and hardware replacement.
HP E24u G4 - E-Series - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class D
Power Consumption (On mode)
13.7 W
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
Sparkling black
53.2 cm x 20.7 cm x 49.49 cm
6.3 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
CSA, UL, TUV GS, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, KC, CEL, EAC, ISC, BIS, low halogen, DisplayPort 1.2, ICE, UAE, Australian-New Zealand MEPS, Vietnam MEPS
3-year warranty
Bundled Services
HP 5 years Next Business Day Onsite Hardware Support for Standard Monitors
Display Type
Energy Class
Class D
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Response Time
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP, Low Blue Light Mode, Flicker Free technology, arsenic-free glass, 3-sided micro-edge, 8-bit Colour Depth, USB-C power delivery up to 65 W, HP Eye Ease
Sparkling black
53.2 cm x 20.7 cm x 49.49 cm - with stand
6.3 kg
DisplayPort 1.2 (HDCP) , DisplayPort 1.2 output (HDCP) , HDMI (HDCP) , USB-C (power up to 65W) , 3 x USB 3.2 Gen 1 downstream
Mechanical
Tilt Angle
-5/+23
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x USB-C cable
Security Slot Type
Kensington security slot
Input Voltage
13.7 W
13.7 kWh/1000h
Power Consumption (Typical)
22 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Center
Dimensions & Weight Details
With stand - width: 53.2 cm - depth: 20.7 cm - height: 49.49 cm - weight: 6.3 kg , Without stand - width: 53.94 cm - depth: 4.7 cm - height: 32.33 cm
Shipping Width
61.1 cm
Shipping Depth
22.3 cm
Shipping Height
39.2 cm
Shipping Weight
8.89 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
Bundled Services
5 °C
35 °C
20 - 80% (non-condensing)
GNXQ HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £24.07
GNXQ HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £36.11
GNXQ HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £18.06
GNXQ HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £12.04
Diagonal Size: 24in
Response Time: 5ms
Speakers: None
Interfaces: USB-C
Interfaces: HDMI
Brand: HP
