Make a great impression on video calls on this 60.45 cm (23.8-inch) full HD conferencing monitor. The integrated, 5MP tilt-adjustable pop-up webcam displays a sharp, detailed picture – even in low light – and the built-in speakers and mic produce clear, life-like sound. Everything you need to present your best self on every call.
More Ports. More Flexibility
Packed with ports including HDMI, DisplayPort , USB-B plus four USB ports. -
Personalized and Protected
Personalize brightness and color settings or set up security protocols all without the OSD. With HP Display Center installed, you have the control. -
Remote Management Reimagined
HP Client Management Script Library (CMSL) makes remote manageability easy to use. This powerful solution works seamlessly with Intune/SCCM to manage your display fleet using PowerShell. -
3-year Limited Warranty
Get peace of mind with a 3-year warranty.
- HP E24mv G4 Conferencing Monitor - E-Series - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class E
- IR camera, USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey with overdrive)
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, VGA, DisplayPort
- Audio Input
- Microphone
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating, Haze 25%
- Voltage
- AC 120/230 V (50/60 Hz)
- Silver, black head
- 53.94 cm x 21.6 cm x 53.07 cm
- 6.5 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified, generation 10, for displays, ENERGY STAR Qualified
- Carbon Footprint
- 260 kg carbon emissions
- TUV GS, VCCI, BSMI, GS, NOM, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, MEPS, KC, CECP, CEL, EAC, CEL Grade 2, SEPA, BIS, low halogen, DisplayPort 1.2, Ukraine, Mercury-free, UAE, Australian-New Zealand MEPS, Vietnam MEPS, TUV low blue light, WW application, TUV-GS, Arsenic-free
- 3-year warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 23.8"
- Built-in Devices
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, On-screen Digital Controls, Low Blue Light Mode, Flicker Free technology, 3-sided micro-edge, edge-lit LED backlight, 8-bit(6-bit + FRC) Colour Depth, HP Eye Ease
- 53.94 cm x 21.6 cm x 53.07 cm - with stand
- 6.5 kg
Audio Input
- Microphone
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- DisplayPort 1.2 , HDMI , VGA , 4 x USB 3.2 Gen 1 upstream , USB (Type B) , Audio line-out (mini-jack)
Mechanical
- Tilt Angle
- -5/+23
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), volume control, detachable stand, VESA interface support, arsenic free, mercury free, microphone mute control
- Cables Included
- 1 x DisplayPort 1.2 cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x USB-A to USB-B cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
- 16 kWh/1000h
- Power Consumption (Typical)
- 28 Watt
- Power Consumption (Max)
- 50 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Display Center
- Dimensions & Weight Details
- With stand - width: 53.94 cm - depth: 21.6 cm - height: 53.07 cm - weight: 6.5 kg , Without stand - width: 53.94 cm - depth: 4.7 cm - height: 35.56 cm - weight: 3.9 kg
- Shipping Width
- 59.6 cm
- Shipping Depth
- 22.5 cm
- Shipping Height
- 41.1 cm
- Shipping Weight
- 10.4 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Carbon Footprint
- Manufacturing (kg CO2e)
- 162
- Logistics (kg CO2e)
- 3
- Use (kg CO2e)
- 76
- EOL (kg CO2e)
- 5
- Total Carbon w/o Use Phase (kg CO2e)
- 250
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
