HP E24M G4 Conferencing 23.8" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: GVKGWS00 Mfr#: 40Z32E9#ABU
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: HDMI, DisplayPort, USB-C
£304.44 ex VAT
£365.32 inc VAT
Conference and connect with ease with the Zoom Certified HP E24m G4 USB-C Conferencing Monitor that has an integrated 5MP, tilt-adjustable webcam, front-firing speakers, and dual mics. Work effortlessly and simplify your set up with one USB-C cable that delivers data, video, and up to 65W of laptop charging.
  • Get Comfortable. Be Productive
    Work effortlessly with 4-way ergonomics and comfortably view your work on a 60.45 cm (23.8-inch) diagonal FHD screen that reduces blue light with HP Eye Ease.
  • Only share when you want to
    Push the webcam down for worry-free privacy.
  • Crystal Clear Audio
    Speakers that deliver crystal-clear audio straight to you.
  • Expand your View
    Daisy chain or run two monitors via DisplayPort .
  • Environmentally Aware. Responsibly Made
    This monitor's plastics consist 90% recycled materials and its recyclable packaging is 100% sustainably sourced.
  • Enhanced Viewing Comfort
    HP Eye Ease keeps you comfortable by reducing blue light.
HP E24m G4 Conferencing - E-Series - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class E
USB Hub, 5.0 megapixel IR camera
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.2745 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Colour Support
16.7 million colours (8-bit)
Colour Gamut
99% sRGB
Input Connectors
Built-in Ethernet
Audio Input
Microphone
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
AC 100-240 V (50/60 Hz)
Silver (stand), black head
53.94 cm x 21.6 cm x 53.07 cm
7.39 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 9, ENERGY STAR Qualified
TUV GS, VCCI, BSMI, NOM, TUV S, WHQL, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, E-Standby, KC, CECP, CEL, EAC, CEL Grade 1, ISC, RCM, SEPA, BIS, DisplayPort 1.2, CE/EMC, ICE, NRCS, Mexico Energy label, Ukraine, UAE, KES, TGM, Belarus Energy
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
23.8"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 85 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Dutch, Japanese
HDCP, Low Blue Light Mode, Flicker Free technology, 3-sided micro-edge, 8-bit Colour Depth, edge-lit LED backlight, HP Eye Ease, Zoom Certified
53.94 cm x 21.6 cm x 53.07 cm - with stand
7.39 kg
Built-in Webcam
Windows Hello compatible
Audio Input
Microphone
Microphone Features
Noise-cancelling
Audio
Speakers - stereo
Output Power / Channel
5 Watt
DisplayPort 1.2 (HDCP) , DisplayPort 1.2 output (HDCP) , HDMI (HDCP) , USB-C/DisplayPort 1.2 Alt Mode (power up to 65W) , 4 x USB (Type A) , Audio line-in/out (mini-jack) , LAN (RJ-45)
Mechanical
Tilt Angle
-5/+23
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), volume control, detachable stand, VESA interface support, microphone mute control
1 x USB-C cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
18 kWh/1000h
Power Consumption (Typical)
37 Watt
Power Consumption (Max)
150 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
HP Display Center, HP Display Manager
Dimensions & Weight Details
With stand - width: 53.94 cm - depth: 21.6 cm - height: 53.07 cm - weight: 7.39 kg , Without stand - width: 53.94 cm - depth: 4.7 cm - height: 35.56 cm - weight: 4.76 kg
Shipping Width
60.3 cm
Shipping Depth
19.2 cm
Shipping Height
42.1 cm
Shipping Weight
10.31 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
8.0
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
GVKG HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.87
GVKG HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £33.70
GVKG HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £6.01
GVKG HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.83
Response Time: 5ms
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: USB-C
Brand: HP
