Conference and connect with ease with the Zoom Certified HP E24m G4 USB-C Conferencing Monitor that has an integrated 5MP, tilt-adjustable webcam, front-firing speakers, and dual mics. Work effortlessly and simplify your set up with one USB-C cable that delivers data, video, and up to 65W of laptop charging.
- HP E24m G4 Conferencing - E-Series - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class F
- USB Hub, 5.0 megapixel IR camera
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 10000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey with overdrive)
- Colour Support
- 16.7 million colours (8-bit)
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Built-in Ethernet
- Audio Input
- Microphone
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating, Haze 25%
- Voltage
- AC 100-240 V (50/60 Hz)
- Silver (stand), black head
- 53.94 cm x 21.6 cm x 53.07 cm
- 7.39 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
- Carbon Footprint
- 270 kg carbon emissions
- TUV GS, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, E-Standby, KC, CECP, CEL, EAC, CEL Grade 1, ISC, RCM, CEL Grade 2, SEPA, BIS, low halogen, DisplayPort 1.2, CE/EMC, ICE, NRCS, Mexico Energy label, Ukraine, UAE, KES, Australian-New Zealand MEPS, Vietnam MEPS, TGM, Belarus Energy, TUV-GS
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 23.8"
- Built-in Devices
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 93
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 85 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Dutch, Japanese
- HDCP, Low Blue Light Mode, Flicker Free technology, 3-sided micro-edge, 8-bit Colour Depth, edge-lit LED backlight, HP Eye Ease, Zoom Certified
- 53.94 cm x 21.6 cm x 53.07 cm - with stand
- 7.39 kg
Built-in Webcam
- Windows Hello compatible
Audio Input
- Microphone
- Microphone Features
- Noise-cancelling
Audio
- Speakers - stereo
- Output Power / Channel
- 5 Watt
- DisplayPort 1.2 (HDCP) , DisplayPort 1.2 output (HDCP) , HDMI (HDCP) , USB-C/DisplayPort 1.2 Alt Mode (power up to 65W) , 4 x USB (Type A) , Audio line-in/out (mini-jack) , LAN (RJ-45)
Mechanical
- Tilt Angle
- -5/+23
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), volume control, detachable stand, VESA interface support, microphone mute control
- Cables Included
- 1 x USB-C cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
- 19 kWh/1000h
- Power Consumption (Typical)
- 37 Watt
- Power Consumption (Max)
- 150 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.3 Watt
- Included Software
- HP Display Center, HP Display Manager
- Dimensions & Weight Details
- With stand - width: 53.94 cm - depth: 21.6 cm - height: 53.07 cm - weight: 7.39 kg , Without stand - width: 53.94 cm - depth: 4.7 cm - height: 35.56 cm - weight: 4.76 kg
- Shipping Width
- 60.3 cm
- Shipping Depth
- 19.2 cm
- Shipping Height
- 42.1 cm
- Shipping Weight
- 10.31 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Carbon Footprint
- Manufacturing (kg CO2e)
- 171
- Logistics (kg CO2e)
- 3
- Use (kg CO2e)
- 89
- EOL (kg CO2e)
- 4
- Total Carbon w/o Use Phase (kg CO2e)
- 270
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
