Conference and connect with ease with the Zoom Certified HP E24m G4 USB-C Conferencing Monitor that has an integrated 5MP, tilt-adjustable webcam, front-firing speakers, and dual mics. Work effortlessly and simplify your set up with one USB-C cable that delivers data, video, and up to 65W of laptop charging.
Get Comfortable. Be Productive
Work effortlessly with 4-way ergonomics and comfortably view your work on a 60.45 cm (23.8-inch) diagonal FHD screen that reduces blue light with HP Eye Ease. -
Only share when you want to
Push the webcam down for worry-free privacy. -
Crystal Clear Audio
Speakers that deliver crystal-clear audio straight to you. -
Expand your View
Daisy chain or run two monitors via DisplayPort . -
Environmentally Aware. Responsibly Made
This monitor's plastics consist 90% recycled materials and its recyclable packaging is 100% sustainably sourced. -
Enhanced Viewing Comfort
HP Eye Ease keeps you comfortable by reducing blue light.
 - HP E24m G4 Conferencing - E-Series - LED monitor - Full HD (1080p) - 23.8"
 - LED-backlit LCD monitor - 23.8"
- Energy Class
 - Class F
 - USB Hub, 5.0 megapixel IR camera
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
 - 0.2745 mm
- Brightness
 - 300 cd/m²
- Contrast Ratio
 - 1000:1 / 10000000:1 (dynamic)
- Response Time
 - 5 ms (grey-to-grey with overdrive)
- Colour Support
 - 16.7 million colours (8-bit)
- Colour Gamut
 - 99% sRGB
- Input Connectors
 - HDMI, DisplayPort, USB-C
- Built-in Ethernet
- Audio Input
 - Microphone
 - Height, pivot (rotation), swivel, tilt
- Screen Coating
 - Anti-glare, 3H Hard Coating, Haze 25%
- Voltage
 - AC 100-240 V (50/60 Hz)
 - Silver (stand), black head
 - 53.94 cm x 21.6 cm x 53.07 cm
 - 7.39 kg
- Localisation
 - English / United Kingdom
- Environmental Standards
 - TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
- Carbon Footprint
 - 270 kg carbon emissions
 - TUV GS, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, E-Standby, KC, CECP, CEL, EAC, CEL Grade 1, ISC, RCM, CEL Grade 2, SEPA, BIS, low halogen, DisplayPort 1.2, CE/EMC, ICE, NRCS, Mexico Energy label, Ukraine, UAE, KES, Australian-New Zealand MEPS, Vietnam MEPS, TGM, Belarus Energy, TUV-GS
- Display Type
- Energy Class
 - Class F
- Diagonal Size
 - 23.8"
- Built-in Devices
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.2745 mm
- Pixel Per Inch
 - 93
- Brightness
 - 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
 - 99% sRGB
- Response Time
- Vertical Refresh Rate
 - 50 - 75 Hz
- Horizontal Refresh Rate
 - 30 - 85 kHz
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
- Backlight Technology
 - LED backlight
- Colour Temperature
 - 6500K
- OSD Languages
 - Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Dutch, Japanese
 - HDCP, Low Blue Light Mode, Flicker Free technology, 3-sided micro-edge, 8-bit Colour Depth, edge-lit LED backlight, HP Eye Ease, Zoom Certified
 - 53.94 cm x 21.6 cm x 53.07 cm - with stand
 - 7.39 kg
Built-in Webcam
 - Windows Hello compatible
Audio Input
 - Microphone
- Microphone Features
 - Noise-cancelling
Audio
 - Speakers - stereo
- Output Power / Channel
 - 5 Watt
 - DisplayPort 1.2 (HDCP) , DisplayPort 1.2 output (HDCP) , HDMI (HDCP) , USB-C/DisplayPort 1.2 Alt Mode (power up to 65W) , 4 x USB (Type A) , Audio line-in/out (mini-jack) , LAN (RJ-45)
Mechanical
- Tilt Angle
 - -5/+23
- Swivel Angle
 - 90
- Rotation Angle
 - 180
- Height Adjustment
 - 150 mm
- VESA Mounting Interface
 - 100 x 100 mm
 - Security lock slot (cable lock sold separately), volume control, detachable stand, VESA interface support, microphone mute control
- Cables Included
 - 1 x USB-C cable - 1.8 m
- Backlight Life
 - 30,000 hours
- Localisation
- Security Slot Type
 - Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
 - 19 kWh/1000h
- Power Consumption (Typical)
 - 37 Watt
- Power Consumption (Max)
 - 150 Watt
- Power Consumption Stand by
 - 0.5 Watt
- Power Consumption Sleep
 - 0.3 Watt
- Included Software
 - HP Display Center, HP Display Manager
- Dimensions & Weight Details
 - With stand - width: 53.94 cm - depth: 21.6 cm - height: 53.07 cm - weight: 7.39 kg , Without stand - width: 53.94 cm - depth: 4.7 cm - height: 35.56 cm - weight: 4.76 kg
- Shipping Width
 - 60.3 cm
- Shipping Depth
 - 19.2 cm
- Shipping Height
 - 42.1 cm
- Shipping Weight
 - 10.31 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- ENERGY STAR Version
 - 8.0
- Carbon Footprint
- Manufacturing (kg CO2e)
 - 171
- Logistics (kg CO2e)
 - 3
- Use (kg CO2e)
 - 89
- EOL (kg CO2e)
 - 4
- Total Carbon w/o Use Phase (kg CO2e)
 - 270
 - 5 °C
 - 35 °C
 - 20 - 80% (non-condensing)
