Inspire joy on your desk with the clean connectivity of the HP E24d G4 FHD USB-C Docking Monitor. Add your everyday accessories at the display, then add your PC with just one USB-C cable. Empower IT to remotely manage HP devices from anywhere on the network through RJ-45.
Ports for everything
Flexibly connect to your devices through DisplayPort , HDMI, and 4 USB ports. Use upstream USB-C port for data, video, and up to 100W power delivery to your PC and downstream USB-C for data and power delivery up to 15W to your phone. -
Take your PC off the desk
Clear your clutter by mounting your HP EliteDesk Mini Desktop PC directly behind the display and powering it through USB-C . Or, lift the whole solution and mount it on a wall or arm. -
Find your comfort zone
Work comfortably with adjustable tilt, height, and swivel settings. Use pivot rotation to conveniently customize portrait or landscape views on multiple displays. -
Adjust your view
Keep your eyes comfortable through the workday with HP Eye Ease, our first built-in, always-on blue light filter that presents your vivid content with zero impact on your color accuracy, no OSD required. -
Complete the picture
Customize a total solution with options like the HP S101 Speaker Bar8, which attaches easily to the lower bezel to add stereo audio at the display. -
Divide and conquer
Manage your display and make it work for you. HP Display Assistant allows you to quickly resize screen partitions so you can work in separate regions of the screen and helps deter theft by dimming a display that's disconnected without approval.
- HP E24d G4 Advanced Docking Monitor - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class E
- Energy Consumption per Year
- 26 kWh
- Power Consumption (On mode)
- 18 W
- Microphone, USB 3.0/USB-C hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Gamut
- 72% NTSC (CIE 1931), 83% NTSC (CIE 1976)
- Input Connectors
- HDMI, DisplayPort, USB-C
- Built-in Ethernet
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, Haze 25%
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 53.94 cm x 4.85 cm x 49.44 cm
- 6.86 kg
- Localisation
- English / United Kingdom
- Plug and Play, TUV GS, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, MEPS, E-Standby, CEC, KC, CECP, CEL, EAC, ISC, BIS, low halogen
- 3-year warranty
- Display Type
- Energy Class
- Class E
- 26 kWh
- Diagonal Size
- 23.8"
- Built-in Devices
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 92.5
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, French, Italian, Portuguese, Spanish, Dutch, Japanese
- Infrared user sensor, HDCP, Low Blue Light Mode, Flicker Free technology, Mercury free, 8-bit gamma, arsenic-free glass, 3 Side Borderless Design, Windows 10 Hello
- Black
- 53.94 cm x 4.85 cm x 49.44 cm - with stand
- 6.86 kg
- HDMI (HDCP) , USB-C upstream/DisplayPort Alt Mode with Power Delivery , DisplayPort , Headphone/microphone combo jack , USB-C downstream , USB 3.0 upstream , 4 x USB 3.0 downstream , Network (RJ-45) , DisplayPort output
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 60
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support
- Included Accessories
- VESA bracket
- Cables Included
- 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB 3.1 Gen 1 cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 18 W
- Power Consumption SDR (On mode)
- 17.9 kWh/1000h
- Power Consumption (Typical)
- 70 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Display Assistant
- OS Required
- Microsoft Windows 7, Windows 8, Windows 10
- Dimensions & Weight Details
- Without stand - width: 53.94 cm - depth: 4.85 cm - height: 32.33 cm - weight: 4.1 kg
- Shipping Width
- 64.6 cm
- Shipping Depth
- 26.9 cm
- Shipping Height
- 43.8 cm
- Shipping Weight
- 11.5 kg
- Limited warranty - parts and labour - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site | In Stock | £22.87 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £33.70 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site | In Stock | £6.01 |
