HP E24d G4 Advanced Docking Monitor 23.8" 1920x1080 HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: GMM2WS00 Mfr#: 6PA50A4#ABU
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, USB-C, HDMI
Hurry, only 1 left in stock!
£381.09 ex VAT
£457.30 inc VAT
Inspire joy on your desk with the clean connectivity of the HP E24d G4 FHD USB-C Docking Monitor. Add your everyday accessories at the display, then add your PC with just one USB-C cable. Empower IT to remotely manage HP devices from anywhere on the network through RJ-45.
  • Ports for everything
    Flexibly connect to your devices through DisplayPort , HDMI, and 4 USB ports. Use upstream USB-C port for data, video, and up to 100W power delivery to your PC and downstream USB-C for data and power delivery up to 15W to your phone.
  • Take your PC off the desk
    Clear your clutter by mounting your HP EliteDesk Mini Desktop PC directly behind the display and powering it through USB-C . Or, lift the whole solution and mount it on a wall or arm.
  • Find your comfort zone
    Work comfortably with adjustable tilt, height, and swivel settings. Use pivot rotation to conveniently customize portrait or landscape views on multiple displays.
  • Adjust your view
    Keep your eyes comfortable through the workday with HP Eye Ease, our first built-in, always-on blue light filter that presents your vivid content with zero impact on your color accuracy, no OSD required.
  • Complete the picture
    Customize a total solution with options like the HP S101 Speaker Bar8, which attaches easily to the lower bezel to add stereo audio at the display.
  • Divide and conquer
    Manage your display and make it work for you. HP Display Assistant allows you to quickly resize screen partitions so you can work in separate regions of the screen and helps deter theft by dimming a display that's disconnected without approval.
HP E24d G4 Advanced Docking Monitor - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class E
Energy Consumption per Year
26 kWh
Power Consumption (On mode)
18 W
Microphone, USB 3.0/USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Gamut
72% NTSC (CIE 1931), 83% NTSC (CIE 1976)
Input Connectors
HDMI, DisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare, Haze 25%
Voltage
53.94 cm x 4.85 cm x 49.44 cm
6.86 kg
English / United Kingdom
Plug and Play, TUV GS, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, MEPS, E-Standby, CEC, KC, CECP, CEL, EAC, ISC, BIS, low halogen
3-year warranty
Display Type
Energy Class
Class E
26 kWh
Diagonal Size
23.8"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
92.5
Brightness
250 cd/m²
Contrast Ratio
Colour Gamut
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, French, Italian, Portuguese, Spanish, Dutch, Japanese
Infrared user sensor, HDCP, Low Blue Light Mode, Flicker Free technology, Mercury free, 8-bit gamma, arsenic-free glass, 3 Side Borderless Design, Windows 10 Hello
53.94 cm x 4.85 cm x 49.44 cm - with stand
6.86 kg
HDMI (HDCP) , USB-C upstream/DisplayPort Alt Mode with Power Delivery , DisplayPort , Headphone/microphone combo jack , USB-C downstream , USB 3.0 upstream , 4 x USB 3.0 downstream , Network (RJ-45) , DisplayPort output
Mechanical
Tilt Angle
-5/+20
Swivel Angle
60
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
VESA bracket
1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB 3.1 Gen 1 cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
18 W
17.9 kWh/1000h
Power Consumption (Typical)
70 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Microsoft Windows 7, Windows 8, Windows 10
Dimensions & Weight Details
Without stand - width: 53.94 cm - depth: 4.85 cm - height: 32.33 cm - weight: 4.1 kg
Shipping Width
64.6 cm
Shipping Depth
26.9 cm
Shipping Height
43.8 cm
Shipping Weight
11.5 kg
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
GMM2 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.87
GMM2 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £33.70
GMM2 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £6.01
Response Time: 5ms
Speakers: None
Interfaces: USB-C
Interfaces: HDMI
Brand: HP
