Intentionally crafted to deliver crisp visuals, personalized comfort, and true flexibility, the HP E24 G5 FHD Monitor redefines comfort, so there's nothing between you and your best. Stylishly designed with the planet in mind, this display is the perfect fit for both the office and home.
Ergonomic Setup Guide
Achieve all-day comfort when you apply the best practices from the Ergonomic Setup Guide. -
Enhanced Viewing Comfort with HP Eye Ease
Always-on, built-in, low-blue light filter that reduces blue light without the yellow color shift now enhanced with a 75Hz refresh rate. -
IPS Panel
No matter where you stand, IPS technology ensures image accuracy and consistency across wide, 178-degree horizontal and vertical viewing angles. -
99% sRGB Color Space
Enjoy what you see on screen with 99% sRGB color space. This display provides ideal color reproduction for vibrant images and videos. -
Endless Adjustability
Work effortlessly with 4-way ergonomics that help keep your neck, shoulders, and back comfortable throughout the day. Customize pivot, tilt, 150 mm height adjust, and swivel settings to fit you, your desk, and your needs. -
More Ports. More Flexibility
More ports means more capabilities. With an HDMI, DisplayPort , USB-B, and 4 USB-A 3.2 ports, you can connect multiple devices like a headset and webcam.
- HP E24 G5 - E-Series - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class D
- Power Consumption (On mode)
- 13.1 W
- USB-B hub enablement
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
- 0.2744 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 8000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey with overdrive)
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating, Haze 25%
- Voltage
- AC 100-240 V (50/60 Hz)
- Black head, black and silver (stand)
- 53.94 cm x 21.1 cm x 50.7 cm
- 5.4 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 220 kg carbon emissions
- VCCI, BSMI, GS, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, PSE Mark, cTUVus, E-Standby, KC, CECP, CEL, EAC, ISC, CEL Grade 2, SEPA, BIS, low halogen, ICE, NRCS, Ukraine, UAE, Australian-New Zealand MEPS, Vietnam MEPS, TGM, TUV Hardware Low Blue Light Certification, Energy Star, Korea MEPS
- 3-year warranty
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 23.8"
- Built-in Devices
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2744 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 86 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Low Blue Light Mode, Flicker Free technology, 3 Side Borderless Design, edge-lit LED backlight, 8-bit(6-bit + FRC) Colour Depth, HP Eye Ease
- 53.94 cm x 21.1 cm x 50.7 cm - with stand
- 5.4 kg
- DisplayPort 1.2 (HDCP) , HDMI (HDCP) , USB 3.2 Gen 1 (power only) , 3 x USB 3.2 Gen 1 , USB (Type B)
Mechanical
- Tilt Angle
- -5/+23
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support
- Cables Included
- 1 x DisplayPort 1.2 cable - 1.8 m , 1 x USB cable - 1.8 m , 1 x HDMI cable - 1.8 m
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 13.1 W
- Power Consumption SDR (On mode)
- 13.1 kWh/1000h
- Power Consumption (Typical)
- 22 watt
- Power Consumption (Max)
- 53 watt
- Power Consumption Stand by
- 0.5 watt
- Dimensions & Weight Details
- With stand - width: 53.94 cm - depth: 21.1 cm - height: 50.7 cm - weight: 5.4 kg , Without stand - width: 53.94 cm - depth: 7.5 cm - height: 32.26 cm - weight: 3.4 kg
- Shipping Width
- 62.1 cm
- Shipping Depth
- 14 cm
- Shipping Height
- 40 cm
- Shipping Weight
- 7.6 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Manufacturing (kg CO2e)
- 156
- Logistics (kg CO2e)
- 2
- Use (kg CO2e)
- 62
- EOL (kg CO2e)
- 3
- Total Carbon w/o Use Phase (kg CO2e)
- 220
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
