HP E24 G5 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor
Quicklinx: H8DMWS00 Mfr#: 6N6E9E9#ABU
£182.00 ex VAT
£218.40 inc VAT
Intentionally crafted to deliver crisp visuals, personalized comfort, and true flexibility, the HP E24 G5 FHD Monitor redefines comfort, so there's nothing between you and your best. Stylishly designed with the planet in mind, this display is the perfect fit for both the office and home.
  • Ergonomic Setup Guide
    Achieve all-day comfort when you apply the best practices from the Ergonomic Setup Guide.
  • Enhanced Viewing Comfort with HP Eye Ease
    Always-on, built-in, low-blue light filter that reduces blue light without the yellow color shift now enhanced with a 75Hz refresh rate.
  • IPS Panel
    No matter where you stand, IPS technology ensures image accuracy and consistency across wide, 178-degree horizontal and vertical viewing angles.
  • 99% sRGB Color Space
    Enjoy what you see on screen with 99% sRGB color space. This display provides ideal color reproduction for vibrant images and videos.
  • Endless Adjustability
    Work effortlessly with 4-way ergonomics that help keep your neck, shoulders, and back comfortable throughout the day. Customize pivot, tilt, 150 mm height adjust, and swivel settings to fit you, your desk, and your needs.
  • More Ports. More Flexibility
    More ports means more capabilities. With an HDMI, DisplayPort , USB-B, and 4 USB-A 3.2 ports, you can connect multiple devices like a headset and webcam.
HP E24 G5 - E-Series - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class D
Power Consumption (On mode)
13.1 W
USB-B hub enablement
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort, USB
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
AC 100-240 V (50/60 Hz)
Black head, black and silver (stand)
53.94 cm x 21.1 cm x 50.7 cm
5.4 kg
English / United Kingdom
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
VCCI, BSMI, GS, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, PSE Mark, cTUVus, KC, CECP, CEL, EAC, ISC, SEPA, BIS, ICE, NRCS, Ukraine, UAE, Australian-New Zealand MEPS, Vietnam MEPS, TGM, Energy Star, TCO Certified Edge, Korea MEPS
3-year warranty
Bundled Services
HP 5 years Next Business Day Onsite Hardware Support for Standard Monitors
Display Type
Energy Class
Class D
Diagonal Size
23.8"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 86 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Low Blue Light Mode, Flicker Free technology, 3 Side Borderless Design, edge-lit LED backlight, 8-bit(6-bit + FRC) Colour Depth, HP Eye Ease
53.94 cm x 21.1 cm x 50.7 cm - with stand
5.4 kg
DisplayPort 1.2 (HDCP) , HDMI (HDCP) , USB 3.2 Gen 1 (power only) , 3 x USB 3.2 Gen 1 , USB (Type B)
Mechanical
Tilt Angle
-5/+23
Swivel Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x DisplayPort 1.2 cable - 1.8 m , 1 x USB cable - 1.8 m , 1 x HDMI cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
13.1 W
13.1 kWh/1000h
Power Consumption (Typical)
22 Watt
Power Consumption (Max)
53 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand - width: 53.94 cm - depth: 21.1 cm - height: 50.7 cm - weight: 5.4 kg , Without stand - width: 53.94 cm - depth: 4.7 cm - height: 32.26 cm - weight: 3.4 kg
Shipping Width
62.1 cm
Shipping Depth
14 cm
Shipping Height
40 cm
Shipping Weight
7.6 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years
Bundled Services
5 °C
35 °C
20 - 80% (non-condensing)
Brand: HP
