Work comfortably and stay focused with the optimized ergonomics and Full HD resolution of the HP E24 G4 FHD Monitor with HP Eye Ease that is designed around you. Make life easy for IT with remote manageability.
Experience simple, convenient connectivity
Connect to your most frequently-used devices with VGA, HDMI, and DisplayPort . Add up to four of your USB accessories right at the monitor with the integrated USB 3.2 hub. -
Find your comfort zone
Work comfortably with adjustable tilt, height, and swivel settings. Use pivot rotation to conveniently customize portrait or landscape views on multiple monitors. -
Personalize and help protect your monitor
Customize your monitor and help deter its theft with easy, intuitive HP Display Center software that lets you tailor your settings, partition screens, and even dim the screen if your monitor is disconnected without approval-all through the host PC. -
Complete the picture
Customize a total solution with options like the HP S101 Speaker Bar, which attaches easily to the lower bezel to add stereo audio on the monitor. -
We have your back
Rest assured that this monitor has been vigorously tested for compatibility across HP PCs and workstations. It's also supported by our three-year standard limited warranty. Extend your protection to cover accidents, next-business day needs, and more with optional HP Care Pack services.
 - HP E24 G4 - E-Series - LED monitor - Full HD (1080p) - 24" - Smart Buy
 - LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
 - Https://eprel.ec.europa.eu/qr/363612
- Energy Class
 - Class D
- Power Consumption (On mode)
 - 14 W
 - USB 3.2 Gen 1 hub
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
 - 0.274 mm
- Brightness
 - 250 cd/m²
- Contrast Ratio
 - 1000:1 / 5000000:1 (dynamic)
- Response Time
 - 5 ms (grey-to-grey with overdrive)
- Input Connectors
 - HDMI, VGA, DisplayPort
 - Height, pivot (rotation), swivel, tilt
- Screen Coating
 - Anti-glare, 3H Hard Coating
- Voltage
 - AC 120/230 V (50/60 Hz)
 - Silver (stand), black head
 - 53.94 cm x 20.7 cm x 49.49 cm
 - 5.7 kg
- Localisation
 - English / United Kingdom
- Manufacturer Selling Program
 - HP Smart Buy
- Environmental Standards
 - TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
 - VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, MEPS, KC, CECP, CEL, EAC, ISC, CEL Grade 2, SEPA, BIS, DisplayPort 1.2, ICE, UAE, Australian-New Zealand MEPS, Vietnam MEPS, WW application
- Bundled Services
 - HP 5 years Next Business Day Onsite Hardware Support for Standard Monitors
- Display Type
- Energy Class
 - Class D
- Diagonal Size
 - 24"
- Viewable Size
 - 23.8"
- Built-in Devices
 - USB 3.2 Gen 1 hub
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.274 mm
- Pixel Per Inch
 - 93
- Brightness
 - 250 cd/m²
- Contrast Ratio
- Response Time
- Vertical Refresh Rate
 - 50 - 60 Hz
- Horizontal Refresh Rate
 - 30 - 80 kHz
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
- Backlight Technology
 - LED backlight
 - Low Blue Light Mode, Flicker Free technology, 3-sided micro-edge, 6-bit + FRC Color Depth, HP Eye Ease
 - 53.94 cm x 20.7 cm x 49.49 cm - with stand
 - 5.7 kg
 - DisplayPort 1.2 , HDMI , VGA , 4 x USB 3.2 Gen 1 , USB (Type B)
Mechanical
- Tilt Angle
 - -5/+23
- Swivel Angle
 - 90
- Rotation Angle
 - 180
- Height Adjustment
 - 150 mm
- VESA Mounting Interface
 - 100 x 100 mm
 - Security lock slot (cable lock sold separately), detachable stand, VESA interface support
- Cables Included
 - 1 x DisplayPort 1.2 cable , 1 x USB cable , 1 x HDMI cable , 1 x VGA cable
- Localisation
 - HP Smart Buy
- Security Slot Type
 - Kensington security slot
- Input Voltage
 - 14 W
- Power Consumption SDR (On mode)
 - 14 kWh/1000h
- Power Consumption (Typical)
 - 26 Watt
- Power Consumption Stand by
 - 0.5 Watt
- Dimensions & Weight Details
 - With stand - width: 53.94 cm - depth: 20.7 cm - height: 49.49 cm - weight: 5.7 kg , Without stand - width: 53.2 cm - depth: 4.7 cm - height: 32.33 cm
- Shipping Width
 - 61.1 cm
- Shipping Depth
 - 22.3 cm
- Shipping Height
 - 39.2 cm
- Shipping Weight
 - 8.4 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Bundled Services
 - 5 °C
 - 35 °C
 - 20 - 80% (non-condensing)
                        HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site | In Stock | £22.36 |
                        HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £32.96 |
                        HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site | In Stock | £5.93 |
                        HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor | In Stock | £10.59 |
