HP E23 G4 FHD 1920X1080 5ms HDMI VGA USB
Quicklinx: G5WMWS00 Mfr#: 9VF96AT#ABU
Work comfortably and stay focused with the optimized ergonomics and Full HD resolution of the HP E23 G4 FHD Monitor with HP Eye Ease that is designed around you. Make life easy for IT with remote manageability.
  • Experience simple, convenient connectivity
    Connect to your most frequently-used devices with VGA, HDMI, and DisplayPort . Add up to four of your USB accessories right at the monitor with the integrated USB 3.2 hub.
  • Find your comfort zone
    Work comfortably with adjustable tilt, height, and swivel settings. Use pivot rotation to conveniently customize portrait or landscape views on multiple monitors.
  • Take your PC off the desk
    Create an efficient, compact, solution when you mount your HP Desktop Mini PC directly on the column stand using the optional HP B300 PC Mounting Bracket.
  • Personalize and help protect your monitor
    Customize your monitor and help deter its theft with easy, intuitive HP Display Center software that lets you tailor your settings, partition screens, and even dim the screen if your monitor is disconnected without approval-all through the host PC.
  • Complete the picture
    Customize a total solution with options like the HP S101 Speaker Bar, which attaches easily to the lower bezel to add stereo audio on the monitor.
  • We have your back
    Rest assured that this monitor has been vigorously tested for compatibility across HP PCs and workstations. It's also supported by our three-year standard limited warranty. Extend your protection to cover accidents, next-business day needs, and more with optional HP Care Pack services.
HP E23 G4 - E-Series - LED monitor - Full HD (1080p) - 23" - Smart Buy
LED-backlit LCD monitor - 23"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/360631
Energy Class
Class E
Power Consumption (On mode)
16 W
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
Black, silver
52.16 cm x 20.7 cm x 48.98 cm
5.4 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, MEPS, KC, CECP, CEL, EAC, ISC, SEPA, BIS, DisplayPort 1.2, ICE, UAE
3-year warranty
Bundled Services
HP 5 years Next Business Day Onsite Hardware Support for Standard Monitors
Display Type
Energy Class
Class E
Diagonal Size
23"
Built-in Devices
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Pixel Per Inch
96
Brightness
250 cd/m²
Contrast Ratio
Response Time
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Low Blue Light Mode, Flicker Free technology, 3-sided micro-edge, 6-bit + FRC Color Depth
Black, silver
52.16 cm x 20.7 cm x 48.98 cm - with stand
5.4 kg
DisplayPort 1.2 , HDMI , VGA , 4 x USB 3.2 Gen 1 downstream , USB 3.2 Gen 1 upstream (Type B)
Mechanical
Tilt Angle
-5/+23
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x DisplayPort 1.2 cable , 1 x USB cable , 1 x HDMI cable
HP Smart Buy
Security Slot Type
Kensington security slot
Input Voltage
16 W
16 kWh/1000h
Power Consumption (Typical)
26 watt
Power Consumption Stand by
0.5 watt
Dimensions & Weight Details
With stand - width: 52.16 cm - depth: 20.7 cm - height: 48.98 cm - weight: 5.4 kg , Without stand - width: 52.16 cm - depth: 4.7 cm - height: 31.31 cm
Shipping Width
58.1 cm
Shipping Depth
22.3 cm
Shipping Height
37.2 cm
Shipping Weight
8 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
Bundled Services
5 °C
35 °C
20 - 80% (non-condensing)
G5WM HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.36
G5WM HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £32.96
G5WM HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.59
