HP E22 G4 22" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: GZQSWS00 Mfr#: 9VH72AA#ABU
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£144.44 ex VAT
£173.32 inc VAT
Work comfortably and stay focused with the optimized ergonomics and Full HD resolution of the HP E22 G4 FHD Monitor with HP Eye Ease that is designed around you. Make life easy for IT with remote manageability.
  • Experience simple, convenient connectivity
    Connect to your most frequently-used devices with VGA, HDMI, and DisplayPort . Add up to four of your USB accessories right at the monitor with the integrated USB 3.2 hub.
  • Find your comfort zone
    Work comfortably with adjustable tilt, height, and swivel settings. Use pivot rotation to conveniently customize portrait or landscape views on multiple monitors.
  • Responsibly made
    Energy efficiency is built into every ENERGY STAR certified, EPEAT 2019 registered, and low halogen display. We go one step further with 100% recyclable packaging that's easily accepted by recycling facilities.
  • Take your PC off the desk
    Create an efficient, compact, solution when you mount your HP Desktop Mini PC directly on the column stand using the optional HP B300 PC Mounting Bracket.
  • Personalize and help protect your monitor
    Customize your monitor and help deter its theft with easy, intuitive HP Display Center software that lets you tailor your settings, partition screens, and even dim the screen if your monitor is disconnected without approval-all through the host PC.
  • Complete the picture
    Customize a total solution with options like the HP S101 Speaker Bar, which attaches easily to the lower bezel to add stereo audio on the monitor.
HP E22 G4 - E-Series - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class D
Power Consumption (On mode)
13 W
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare 3H hardness
Voltage
48.87 cm x 20.7 cm x 48.06 cm
5.3 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, KC, CEL, EAC, CEL Grade 1, ISC, low halogen, DisplayPort 1.2, ICE, HP GSE, Australian-New Zealand MEPS, Vietnam MEPS
3-year warranty
Bundled Services
HP 5 years Next Business Day Onsite Hardware Support for Standard Monitors
Display Type
Energy Class
Class D
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Gamut
72% NTSC
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Low Blue Light Mode, Flicker Free technology, 3-sided micro-edge, 6-bit + FRC Color Depth, HP Eye Ease, 72% NTSC colour gamut
48.87 cm x 20.7 cm x 48.06 cm - with stand
5.3 kg
DisplayPort 1.2 , HDMI , VGA , 4 x USB 3.2 Gen 1 downstream , USB 3.2 Gen 1 upstream (Type B)
Mechanical
Tilt Angle
-5/+23
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, arsenic free, mercury free
1 x HDMI cable - 1.8 m , 1 x DisplayPort 1.2 cable - 1.8 m , 1 x USB-B to USB-A cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
13 W
13 kWh/1000h
Power Consumption (Typical)
23 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Center
Dimensions & Weight Details
With stand - width: 48.87 cm - depth: 20.7 cm - height: 48.06 cm - weight: 5.3 kg , Without stand - width: 48.87 cm - depth: 4.7 cm - height: 29.46 cm - weight: 2.88 kg
Shipping Width
56.5 cm
Shipping Depth
21.1 cm
Shipping Height
35 cm
Shipping Weight
7.7 kg
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
ENERGY STAR Version
8.0
Limited warranty - parts and labour - 3 years
Bundled Services
5 °C
35 °C
20 - 80% (non-condensing)
GZQS HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.36
GZQS HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £32.96
GZQS HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £5.89
GZQS HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.59
Diagonal Size: 22in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: HP
