HP E14 G4 14" 1920x1080 5ms DisplayPort LED Portable Monitor
Quicklinx: G28PWS00 Mfr#: 1B065AA#AC3
Double down on your productivity with the HP E14 G4 Portable Monitor. Remove from the soft sleeve, stand up on the kickstand, and connect with the simplicity of just one USB-C cable. Enjoy a great view indoors or outdoors from an extra-bright screen.
  • Easy USB-C efficiency
    Set up quickly with just one USB-C cable that transfers video and powers your monitor from your laptop.
  • Share-worthy visuals
    Slide the monitor out of the sleeve to reveal the 14" diagonal IPS glass panel screen with 1920 x 1080 resolution, a 16:9 aspect ratio, and fast 5 ms response time-perfect for single and group viewing.
  • Form meets function
    Carry a display that sets a style standard with an aesthetic that complements HP PCs. The soft, easy-to-carry sleeve helps protect the display when you're on the move. Find a comfortable viewing position with the adjustable kickstand on the back.
  • Customize your settings
    Control brightness, contrast, and response time, and activate HP Low Blue Light mode to filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing, all from the intuitive OSD.
  • Global reassurance
    Rest assured that your IT investment is supported by a three-year standard limited warranty. To extend your protection, select an optional HP Care service.
HP E14 G4 Portable - LED monitor - Full HD (1080p) - 14" - HDR
LED-backlit LCD monitor - 14"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/296893
Energy Class
Class B
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1611 mm
Brightness
400 cd/m²
Contrast Ratio
800:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Colour Gamut
72% NTSC
Input Connectors
2xUSB-C
Display Position Adjustments
Tilt
Screen Coating
Anti-glare 3H hardness, Haze 24%
Silver stand
32.14 cm x 1.52 cm x 21 cm
640 g
Environmental Standards
ENERGY STAR Qualified
UL, TUV, TUV GS, VCCI, BSMI, NOM, WHQL, CB, CCC, FCC, ISO 9241-307, KCC, WEEE, Green Mark, ICES, cTUVus, KC, EAC, ISC, BIS, low halogen, UAE, Vietnam MEPS
3-year warranty
Display Type
Energy Class
Class B
Diagonal Size
14"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1611 mm
Pixel Per Inch
157
Brightness
400 cd/m²
Contrast Ratio
Colour Gamut
72% NTSC
Response Time
Vertical Refresh Rate
59 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
Edge-lit LED
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
On-screen Digital Controls, Low Blue Light Mode, Flicker Free technology, Mercury free, arsenic-free glass, 3-sided micro-edge, 8-bit Colour Depth, 72% NTSC colour gamut
Silver stand
32.14 cm x 1.52 cm x 21 cm - with stand
640 g
2 x USB-C/DisplayPort 1.2 Alt Mode
Mechanical
Tilt
Tilt Angle
0/+78
Sleeve
1 x USB-C cable
Backlight Life
15,000 hours
5 kWh/1000h
Power Consumption (Typical)
6 Watt
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
With stand - width: 32.14 cm - depth: 1.52 cm - height: 21 cm - weight: 640 g , With stand - width: 32.14 cm
Shipping Width
40.5 cm
Shipping Depth
6.1 cm
Shipping Height
28.4 cm
Shipping Weight
1.54 kg
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
8.0
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
