Double down on your productivity with the HP E14 G4 Portable Monitor. Remove from the soft sleeve, stand up on the kickstand, and connect with the simplicity of just one USB-C cable. Enjoy a great view indoors or outdoors from an extra-bright screen.
Easy USB-C efficiency
Set up quickly with just one USB-C cable that transfers video and powers your monitor from your laptop. -
Share-worthy visuals
Slide the monitor out of the sleeve to reveal the 14" diagonal IPS glass panel screen with 1920 x 1080 resolution, a 16:9 aspect ratio, and fast 5 ms response time-perfect for single and group viewing. -
Form meets function
Carry a display that sets a style standard with an aesthetic that complements HP PCs. The soft, easy-to-carry sleeve helps protect the display when you're on the move. Find a comfortable viewing position with the adjustable kickstand on the back. -
Customize your settings
Control brightness, contrast, and response time, and activate HP Low Blue Light mode to filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing, all from the intuitive OSD. -
Global reassurance
Rest assured that your IT investment is supported by a three-year standard limited warranty. To extend your protection, select an optional HP Care service.
- HP E14 G4 Portable - LED monitor - Full HD (1080p) - 14" - HDR
- LED-backlit LCD monitor - 14"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/296893
- Energy Class
- Class B
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.1611 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- 800:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey with overdrive)
- Colour Gamut
- 72% NTSC
- Input Connectors
- 2xUSB-C
- Tilt
- Screen Coating
- Anti-glare 3H hardness, Haze 24%
- Silver stand
- 32.14 cm x 1.52 cm x 21 cm
- 640 g
- Environmental Standards
- ENERGY STAR Qualified
- UL, TUV, TUV GS, VCCI, BSMI, NOM, WHQL, CB, CCC, FCC, ISO 9241-307, KCC, WEEE, Green Mark, ICES, cTUVus, KC, EAC, ISC, BIS, low halogen, UAE, Vietnam MEPS
- 3-year warranty
- Display Type
- Energy Class
- Class B
- Diagonal Size
- 14"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.1611 mm
- Pixel Per Inch
- 157
- Brightness
- 400 cd/m²
- Contrast Ratio
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 59 - 60 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- Edge-lit LED
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- On-screen Digital Controls, Low Blue Light Mode, Flicker Free technology, Mercury free, arsenic-free glass, 3-sided micro-edge, 8-bit Colour Depth, 72% NTSC colour gamut
- Silver stand
- 32.14 cm x 1.52 cm x 21 cm - with stand
- 640 g
- 2 x USB-C/DisplayPort 1.2 Alt Mode
Mechanical
- Tilt
- Tilt Angle
- 0/+78
- Included Accessories
- Sleeve
- Cables Included
- 1 x USB-C cable
- Backlight Life
- 15,000 hours
- Power Consumption SDR (On mode)
- 5 kWh/1000h
- Power Consumption (Typical)
- 6 Watt
- Power Consumption Stand by
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 32.14 cm - depth: 1.52 cm - height: 21 cm - weight: 640 g , With stand - width: 32.14 cm
- Shipping Width
- 40.5 cm
- Shipping Depth
- 6.1 cm
- Shipping Height
- 28.4 cm
- Shipping Weight
- 1.54 kg
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Limited warranty - parts and labour - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
