Work comfortably and stay focused with the optimized ergonomics and WUXGA resolution of the HP E24i G4 WUXGA Monitor with HP Eye Ease that is designed around you. Make life easy for IT with remote manageability.
Experience simple, convenient connectivity
Connect to your most frequently-used devices with VGA, HDMI, and DisplayPort . Add up to four of your USB accessories right at the monitor with the integrated USB 3.2 hub. -
Find your comfort zone
Work comfortably with adjustable tilt, height, and swivel settings. Use pivot rotation to conveniently customize portrait or landscape views on multiple monitors. -
Take your PC off the desk
Create an efficient, compact, solution when you mount your HP Desktop Mini PC directly on the column stand using the optional HP B300 PC Mounting Bracket. -
Personalize and help protect your monitor
Customize your monitor and help deter its theft with easy, intuitive HP Display Center software that lets you tailor your settings, partition screens, and even dim the screen if your monitor is disconnected without approval-all through the host PC. -
Complete the picture
Customize a total solution with options like the HP S101 Speaker Bar, which attaches easily to the lower bezel to add stereo audio on the monitor. -
We have your back
Rest assured that this monitor has been vigorously tested for compatibility across HP PCs and workstations. It's also supported by our three-year standard limited warranty. Extend your protection to cover accidents, next-business day needs, and more with optional HP Care Pack services.
- HP E24i G4 - E-Series - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/359981
- Energy Class
- Class D
- Energy Consumption per Year
- 24 kWh
- Power Consumption (On mode)
- 15.3 W
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- WUXGA 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey with overdrive)
- Colour Support
- 16.7 million colours (8-bit)
- Colour Gamut
- 72% (CIE 1931), 83% (CIE 1976)
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Haze 25%, anti-glare 3H hardness
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 53.2 cm x 20.69 cm x 50.96 cm
- 6.06 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
- Plug and Play, TUV GS, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, E-Standby, CEC, KC, CECP, CEL, EAC, CEL Grade 1, ISC, CEL Grade 2, SEPA, BIS, low halogen, DisplayPort 1.2, ICE, HP GSE, Australian-New Zealand MEPS, Vietnam MEPS, TGM, TUV low blue light, WW application, TUV-GS
- 3-year warranty
- Bundled Services
- HP 5 years Next Business Day Onsite Hardware Support for Standard Monitors
- Display Type
- Energy Class
- Class D
- 24 kWh
- Diagonal Size
- 24"
- Built-in Devices
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 94
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, Low Blue Light Mode, 3-sided micro-edge, 8-bit Colour Depth, HP Eye Ease
- Black
- 53.2 cm x 20.69 cm x 50.96 cm - with stand
- 6.06 kg
- DisplayPort 1.2 , HDMI , VGA , 3 x USB 3.2 Gen 1 downstream , USB 3.2 Gen 1 downstream (fast charging) , USB 3.2 Gen 1 upstream (Type B)
Mechanical
- Tilt Angle
- -5/+23
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, arsenic free, mercury free
- Cables Included
- 1 x HDMI cable - 1.8 m , 1 x DisplayPort 1.2 cable - 1.8 m , 1 x USB-B to USB-A cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 15.3 W
- Power Consumption SDR (On mode)
- 15.3 kWh/1000h
- Power Consumption (Typical)
- 36 watt
- Power Consumption Stand by
- 0.5 watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 53.2 cm - depth: 20.69 cm - height: 50.96 cm - weight: 6.06 kg , Without stand - width: 53.2 cm - depth: 4.7 cm - height: 35.27 cm - weight: 3.6 kg
- Shipping Width
- 60.5 cm
- Shipping Depth
- 42 cm
- Shipping Height
- 22.4 cm
- Shipping Weight
- 9.12 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
- Bundled Services
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site | In Stock | £22.83 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £33.64 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site | In Stock | £6.01 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor | In Stock | £10.81 |
