HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor
Quicklinx: G80VWS00 Mfr#: 9VJ40AA#ABU
Diagonal Size: 24in
Max Resolution: 1920 x 1200
Response Time: 5ms
Speakers: None
Interfaces: HDMI, DisplayPort, VGA (HD-15)
£135.83 ex VAT
£162.99 inc VAT
Work comfortably and stay focused with the optimized ergonomics and WUXGA resolution of the HP E24i G4 WUXGA Monitor with HP Eye Ease that is designed around you. Make life easy for IT with remote manageability.
  • Experience simple, convenient connectivity
    Connect to your most frequently-used devices with VGA, HDMI, and DisplayPort . Add up to four of your USB accessories right at the monitor with the integrated USB 3.2 hub.
  • Find your comfort zone
    Work comfortably with adjustable tilt, height, and swivel settings. Use pivot rotation to conveniently customize portrait or landscape views on multiple monitors.
  • Take your PC off the desk
    Create an efficient, compact, solution when you mount your HP Desktop Mini PC directly on the column stand using the optional HP B300 PC Mounting Bracket.
  • Personalize and help protect your monitor
    Customize your monitor and help deter its theft with easy, intuitive HP Display Center software that lets you tailor your settings, partition screens, and even dim the screen if your monitor is disconnected without approval-all through the host PC.
  • Complete the picture
    Customize a total solution with options like the HP S101 Speaker Bar, which attaches easily to the lower bezel to add stereo audio on the monitor.
  • We have your back
    Rest assured that this monitor has been vigorously tested for compatibility across HP PCs and workstations. It's also supported by our three-year standard limited warranty. Extend your protection to cover accidents, next-business day needs, and more with optional HP Care Pack services.
HP E24i G4 - E-Series - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/359981
Energy Class
Class D
Energy Consumption per Year
24 kWh
Power Consumption (On mode)
15.3 W
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
WUXGA 1920 x 1200 at 60 Hz
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Colour Support
16.7 million colours (8-bit)
Colour Gamut
72% (CIE 1931), 83% (CIE 1976)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Haze 25%, anti-glare 3H hardness
Voltage
53.2 cm x 20.69 cm x 50.96 cm
6.06 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
Plug and Play, TUV GS, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, E-Standby, CEC, KC, CECP, CEL, EAC, CEL Grade 1, ISC, CEL Grade 2, SEPA, BIS, low halogen, DisplayPort 1.2, ICE, HP GSE, Australian-New Zealand MEPS, Vietnam MEPS, TGM, TUV low blue light, WW application, TUV-GS
3-year warranty
Bundled Services
HP 5 years Next Business Day Onsite Hardware Support for Standard Monitors
Display Type
Energy Class
Class D
24 kWh
Diagonal Size
24"
Built-in Devices
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
94
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Low Blue Light Mode, 3-sided micro-edge, 8-bit Colour Depth, HP Eye Ease
53.2 cm x 20.69 cm x 50.96 cm - with stand
6.06 kg
DisplayPort 1.2 , HDMI , VGA , 3 x USB 3.2 Gen 1 downstream , USB 3.2 Gen 1 downstream (fast charging) , USB 3.2 Gen 1 upstream (Type B)
Mechanical
Tilt Angle
-5/+23
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, arsenic free, mercury free
1 x HDMI cable - 1.8 m , 1 x DisplayPort 1.2 cable - 1.8 m , 1 x USB-B to USB-A cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
15.3 W
15.3 kWh/1000h
Power Consumption (Typical)
36 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 53.2 cm - depth: 20.69 cm - height: 50.96 cm - weight: 6.06 kg , Without stand - width: 53.2 cm - depth: 4.7 cm - height: 35.27 cm - weight: 3.6 kg
Shipping Width
60.5 cm
Shipping Depth
42 cm
Shipping Height
22.4 cm
Shipping Weight
9.12 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
Bundled Services
5 °C
35 °C
20 - 80% (non-condensing)
G80V HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.36
G80V HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £32.96
G80V HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £5.93
G80V HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.59
Diagonal Size: 24in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: VGA (HD-15)
Brand: HP
