Go big or go home with the HP DreamColor Z32x 80,01 cm (31.5") UHD Display, HP's largest UHD 4K display, which delivers a staggering 8 million pixels and 4K resolution and has award- winning HP DreamColor technology built right in.
Admire every detail
Explore your creativity with 8 million pixels and 4K resolution-four times that of a traditional Full HD display-on an extra-large 80,01 cm (31.5") diagonal screen. -
Color as only HP DreamColor can do it
Get exceptional, consistent 10-bit color precision and out-of-the-box, color-calibrated sRGB, BT709, and Adobe RGB coverage from HP DreamColor technology. Use the HP DreamColor Calibration Kit or your choice of tool for precise color adjustments. -
Boost your productivity
Connect to an array of your everyday devices right at the display with HDMI, mDP, DP, MHL, and a USB 3.0 hub with a fast-charging port. View up to four simultaneous feeds with picture-in-picture or picture-by-picture.
- HP DreamColor Z32x Professional - LED monitor - 31.5"
- LED-backlit LCD monitor - 31.5"
- Energy Class
- Class C
- Energy Consumption per Year
- 116 kWh
- Power Consumption (On mode)
- 80 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 at 60 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 8 ms (grey-to-grey)
- Input Connectors
- 2xHDMI, DisplayPort, Mini DisplayPort, MHL
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V
- Black
- 73.71 cm x 24.55 cm x 61.38 cm
- 10.8 kg
- Localisation
- English / United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, KC, CECP, CEL, EPA, ISC, SEPA
- 3-year warranty
- Display Type
- Energy Class
- Class C
- 116 kWh
- Diagonal Size
- 31.5"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Picture in picture, picture by picture, HDCP, DreamColor, Mobile High-Definition Link (MHL), Mercury free, arsenic-free glass
- Black
- 73.71 cm x 24.55 cm x 61.38 cm - with stand
- 10.8 kg
- MHL / HDMI (HDCP) , HDMI (HDCP) , DisplayPort (HDCP) , Mini DisplayPort , 4 x USB 3.0 downstream , Audio line-out , USB 3.0 upstream
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 130 mm
- Security lock slot (cable lock sold separately), 1 USB 3.0 fast charging port
- Cables Included
- 1 x DisplayPort cable , 1 x Mini DisplayPort cable , 1 x USB cable
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 120/230 V
- 80 W
- Power Consumption (Typical)
- 80 Watt
- Power Consumption Stand by
- 0.45 Watt
- On / Off Switch
- Included Software
- Drivers & Utilities, HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 73.71 cm - depth: 24.55 cm - height: 61.38 cm - weight: 10.8 kg , Without stand - width: 73.71 cm - depth: 7.01 cm - height: 43.46 cm - weight: 7.8 kg
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
