HP DreamColour Z32X LED 31.5" Monitor 3840x2160 8MS
Quicklinx: C7YWWS00 Mfr#: M2D46AT#ABU
Go big or go home with the HP DreamColor Z32x 80,01 cm (31.5") UHD Display, HP's largest UHD 4K display, which delivers a staggering 8 million pixels and 4K resolution and has award- winning HP DreamColor technology built right in.
  • Customize your comfort
    Work comfortably with adjustable tilt, height adjustment, and swivel settings. Use pivot rotation for portrait or landscape views when using multiple displays. An integrated HP Quick Release Bracket supports wall mounting.
  • Your monitor's new best friend
    Design the screen for how you work with HP Display Assistant software.
  • Designed with the environment in mind
    Be a better consumer with a display that has environmentally responsible components.
HP DreamColor Z32x Professional - LED monitor - 31.5" - Smart Buy
LED-backlit LCD monitor - 31.5"
Energy Class
Class C
Energy Consumption per Year
116 kWh
Power Consumption (On mode)
80 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 at 60 Hz
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Input Connectors
2xHDMI, DisplayPort, Mini DisplayPort, MHL
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 120/230 V
73.71 cm x 24.55 cm x 61.38 cm
10.8 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, KC, CECP, CEL, EPA, ISC, SEPA
3-year warranty
Display Type
Energy Class
Class C
116 kWh
Diagonal Size
31.5"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Response Time
8 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Picture in picture, picture by picture, HDCP, DreamColor, Mobile High-Definition Link (MHL), Mercury free, arsenic-free glass
73.71 cm x 24.55 cm x 61.38 cm - with stand
10.8 kg
MHL / HDMI (HDCP) , HDMI (HDCP) , DisplayPort (HDCP) , Mini DisplayPort , 4 x USB 3.0 downstream , Audio line-out , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
Security lock slot (cable lock sold separately), 1 USB 3.0 fast charging port
1 x DisplayPort cable , 1 x Mini DisplayPort cable , 1 x USB cable
HP Smart Buy
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V
80 W
Power Consumption (Typical)
80 Watt
Power Consumption Stand by
0.45 Watt
On / Off Switch
Included Software
Drivers & Utilities, HP Display Assistant
Dimensions & Weight Details
With stand - width: 73.71 cm - depth: 24.55 cm - height: 61.38 cm - weight: 10.8 kg , Without stand - width: 73.71 cm - depth: 7.01 cm - height: 43.46 cm - weight: 7.8 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
