Go big or go home with the HP DreamColor Z32x 80,01 cm (31.5") UHD Display, HP's largest UHD 4K display, which delivers a staggering 8 million pixels and 4K resolution and has award- winning HP DreamColor technology built right in.
Customize your comfort
Work comfortably with adjustable tilt, height adjustment, and swivel settings. Use pivot rotation for portrait or landscape views when using multiple displays. An integrated HP Quick Release Bracket supports wall mounting. -
Your monitor's new best friend
Design the screen for how you work with HP Display Assistant software. -
Designed with the environment in mind
Be a better consumer with a display that has environmentally responsible components.
- HP DreamColor Z32x Professional - LED monitor - 4K - 31.5"
- LED-backlit LCD monitor - 31.5"
- Energy Class
- Class A
- Energy Consumption per Year
- 28 kWh
- Power Consumption (On mode)
- 19 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.182 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Input Connectors
- 2xHDMI, DisplayPort, Mini DisplayPort, MHL
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 73.71 cm x 24.54 cm x 61.38 cm
- 10.8 kg
- Localisation
- English / United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, KC, CECP, EPA, CEL Grade 1, ISC, SEPA
- 5-year warranty
- Display Type
- Energy Class
- Class A
- 28 kWh
- Diagonal Size
- 31.5"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.182 mm
- Pixel Per Inch
- 140
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 24 - 60 Hz
- Horizontal Refresh Rate
- 24 - 135 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Japanese
- Picture in picture, picture by picture, HDCP, DreamColor, Mobile High-Definition Link (MHL) 2.0, Colour gamut BT.709, arsenic-free glass
- Black
- 73.71 cm x 24.54 cm x 61.38 cm - with stand
- 10.8 kg
- MHL / HDMI (HDCP) , HDMI (HDCP) , DisplayPort (HDCP) , Mini DisplayPort , 4 x USB 3.0 downstream , Audio line-out , USB 3.0 upstream
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support, 1 USB 3.0 charging port, low halogen
- Cables Included
- 1 x DisplayPort cable - 1.8 m , 1 x Mini DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
- Backlight Life
- 40,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 19 W
- Power Consumption (Typical)
- 86 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- Included Software
- Drivers & Utilities, HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 73.71 cm - depth: 24.55 cm - height: 61.38 cm - weight: 10.8 kg , Without stand - width: 73.71 cm - depth: 7.01 cm - height: 43.46 cm - weight: 7.8 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 5 years - on-site - response time: next business day
