HP Dragonfly Folio G3 Intel Core i7-1255U 16GB 512GB SSD 13.5" Windows 11 Professional 64-bit
Quicklinx: H4HSWS00 Mfr#: 6T1G4EA#ABU
  • Core i7
  • IEEE 802.11n
Empower hands-on, visual, collaborative thinkers to fluidly create, capture, and share ideas when and where they strike. The flexible, highly secure, multi-mode HP Dragonfly Folio anticipates and adapts to your life, your work, and your surroundings with intelligent features that enable seamless experiences without interruption or distraction.
  • Windows 11
    Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology.
  • High performance, high portability
    Get the exceptional combination of responsive performance, connectivity and speed with a 12th Gen Intel Core processor that lets you launch, create, and connect fast and reliably.
  • Security is your top priority
    The HP Wolf Pro Security Edition provides preconfigured enterprise-level PC protection for small and medium sized businesses.
  • myHP
    Enable hardware and software innovations from HP with the myHP application. This single dashboard houses access to settings for audio, video, the programmable key, and more.
  • Designed for where life takes you
    Express yourself in almost any light using the ultra-bright outdoor viewable touch display with anti-glare and ambient light sensors.
  • Fast and efficient wireless LAN
    The portability of your PC and the reliability of a fast connection determines where you can work. Get a fast and reliable connection in dense wireless environments with gigabit-speed Wi-Fi 6.
HP Dragonfly Folio G3 Notebook - 13.5" - Intel Core i7 - 1255U - 16 GB RAM - 512 GB SSD - 4G LTE-A Pro - UK - with HP Wolf Pro Security Edition (1 year)
Notebook - slider
Operating System
Win 11 Pro - English
Intel Core i7 (12th Gen) - 1255U / 1.7 GHz, up to 4.7 GHz / 12 MB Cache
16 GB LPDDR5 (provided memory is soldered)
Storage
512 GB SSD - NVMe
Display
13.5" WLED touchscreen 1920 x 1280 / WUXGA+ @ 60 Hz
Graphics
Intel Iris Xe Graphics
Input Device
Digital pen, ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 5.2, 802.11a/b/g/n/ac/ax (Wi-Fi 6E)
Wireless Broadband (WWAN)
4G LTE Advanced Pro
Service Provider
Service not included
4-cell
HP Tamper Lock
Security
Trusted Platform Module (TPM 2.0) Security Chip
29.64 cm x 23.43 cm x 1.79 cm
1.4 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Bundled with
Notebook - slider
Operating System
Windows 11 Pro - English
Bundled with
Processor / Chipset
CPU
Intel Core i7 (12th Gen) 1255U / 1.7 GHz
Max Turbo Speed
4.7 GHz
Number of Cores
10-core
Cache
L3 - 12 MB
Intel Turbo Boost Technology
RAM
16 GB (provided memory is soldered)
LPDDR5 SDRAM - non-ECC
Speed
6400 MHz
Rated Speed
6400 MHz
Storage
Main Storage
512 GB SSD M.2 2280 PCIe - NVM Express (NVMe)
Display
13.5" - IPS
LCD Backlight Technology
WLED backlight
Touchscreen
Resolution
1920 x 1280 (WUXGA+)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Image Brightness
400 cd/m²
Colour Gamut
100% sRGB, 72% NTSC
Narrow-bezel design, Low Blue Light technology, HP Eye Ease, Corning Gorilla glass 7, WUXGA+ ultra wide-viewing angle (UWVA) anti-glare eDP
Keyboard Name
HP Premium
Audio & Video
Graphics Processor
Video System Features
Functions as Intel UHD graphics (for single-channel memory)
Camera
Resolution
8 Megapixel
Camera Features
IR camera, 100° view, HP Camera Privacy Key
Sound
Four speakers, dual array microphone
Codec
Realtek ALC3315
Audio Features
Output: Bang & Olufsen Audio, discrete amplifiers
Input
Keyboard, digital pen, ClickPad
Keyboard Backlight
Keyboard Layout
Pen slot, multi-touch clickpad, gesture function, spill-resistant
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wi-Fi 6E AX 211 - PCI Express Mini Card (M.2)
Miracast, dual stream (2x2), MU-MIMO
Wi-Fi CERTIFIED
Generation
4G
DC-HSPA+, LTE Advanced Pro
Controller
Intel XMM 7560 R+ - M.2 3042
Max Transfer Rate
978 Mbps
Service Provider
Navigation
Receiver
A-GPS/GPS/GLONASS/BeiDou
4-cell lithium polymer
53.2 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
65 watt, 5 / 9 / 12 / 15 / 20 V, 8 A
Connections & Expansion
Slots
1 x Nano-SIM card (1 available)
Interfaces Details
2 x USB4 (supports Thunderbolt 4, DisplayPort 1.4 Alt Mode) (Power Delivery) , Headphone/microphone combo jack
Software
Software Included
HP Support Assistant, HP Power Manager, HP Hotkey Support, HP Client Catalogue (free download), HP PC Hardware Diagnostics, HP Notifications, HP Connection Optimizer, HP Sure Click, HP Privacy Settings, HP Cloud Recovery, HP Sure Sense, HP Sure Admin, HP QuickDrop, HP Client Management Script Library (free download), HP BIOSphere Gen6, HP Wake on WLAN, myHP, HP Image Assistant Gen5 (free download), HP Client Security Manager Gen7, Tile, HP Easy Clean, HP Smart Support (free download), HP Quick Touch, HP Sure Recover Gen5, HP Sure Run Gen5, HP Sure Start Gen7, HP Driver Packs (free download), HP Manageability Integration Kit Gen4 (free download)
Integrated Options
HP Tamper Lock
Security
BIOS Absolute Persistence, HP Automatic Drive Lock, HP DriveLock, HP Fast Charge, BIOS Update via Network, MIL-STD-810H tested
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion sensor
Security Slot Type
Kensington nano security slot
HP 65 Watt nPFC Smart USB-C AC Adapter, HP Pen
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FIPS 140-2 Level 2, FCC, A-Tick, ICES, Common Criteria EAL4+, KC, EAC, CIT, ICCP, AUS/NZ, BNCI
Localization
1.4 kg
Dimensions (WxDxH) / Weight Details
6.9 cm x 44.9 cm x 30.5 cm
Sustainability Information
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (5)
Get more from your purchase from one of our essential accessories
H4HS HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £185.94
H4HS HP USB-C Power Adapter - 65 Watt In Stock £56.88
H4HS HP Prelude Top Load 15.6" Notebook Carrying Case In Stock £10.26
H4HS HP USB-C LC Power Adapter - 65 Watt In Stock £15.15
H4HS HP Renew Business - Notebook carrying shoulder bag - 17.3" In Stock £18.95
Other bundles (22)
H4HS HP USB-C To VGA Adapter In Stock £23.07
H4HS HP USB-C to HDMI 2.0 Adapter In Stock £47.48
H4HS HP 455 Programmable Keyboard - Wireless - UK In Stock £46.54
H4HS HP USB-C to RJ45 Adapter G2 In Stock £13.11
H4HS Poly DA75 Sound Card In Stock £27.52
H4HS Poly DA85 Headset Cable - USB-C to Quick Disconnect In Stock £43.34
H4HS Poly Voyager 4320 UC V4320-M C USB-A CS WW In Stock £111.53
H4HS Poly Voyager 4320 UC V4320 C USB-A CS WW In Stock £117.00
H4HS Poly Voyager 4310 UC V4310-M C USB-A CS WW In Stock £108.17
H4HS Poly Voyager 4310 UC V4310 C USB-A CS WW In Stock £111.00
H4HS Poly Sync 10 SY10-M USB-A/C WW In Stock £55.47
H4HS Poly Sync 40 SY40-M WW In Stock £123.47
H4HS HyperX Cloud Stinger 2 Core Gaming Headset In Stock £37.68
H4HS HyperX SoloCast USB Microphone In Stock £50.55
H4HS HyperX Pulsefire Core Gaming Mouse In Stock £28.26
H4HS HyperX Pulsefire Mat Gaming Mouse Pad In Stock £12.63
H4HS HyperX Wrist Rest In Stock £20.22
H4HS HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £167.73
H4HS HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor In Stock £501.52
H4HS HP 732pk Series 7 Pro 32" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor In Stock £621.41
H4HS HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor In Stock £168.87
H4HS HP 715 - mouse - multi-device, rechargeable - Bluetooth 3.0, 2.4 GHz - black In Stock £50.45
