HP - DDR3 - 16 GB - DIMM 240-pin - 1866 MHz / PC3-14900 - CL13 - 1.5 V - registered - ECC
Memory quality and reliability
Testing is performed and optimized on every HPE ProLiant server platform to ensure upmost compatibility, performance and reliability. -
Power efficiency
HPE SmartMemory DDR3 Registered memory is engineered to achieve a high performance level.
- HPE - DDR3 - module - 16 GB - DIMM 240-pin - 1866 MHz / PC3-14900 - registered
- Product Type
- Memory module
- Capacity
- 16 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1866 MHz (PC3-14900)
- Latency Timings
- CL13
- Dual rank, registered
- Voltage
- 1.5 V
- OEM Manufacturer Equivalent Part Number
- HP 715274-001
- Designed For
- ProLiant DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Performance, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Performance, DL380p Gen8 Special
- Capacity
- 16 GB
- Upgrade Type
- System specific
- HP 715274-001
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL13
- ECC
- Chips Organization
- X4
- Voltage
- 1.5 V
- Designed For
- HPE ProLiant DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Performance, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Performance, DL380p Gen8 Special
