Wrap your HP Desktop Mini PC in the HP Desktop Mini Security/Dual VESA Sleeve v2 to securely mount it behind your display, position the solution on a wall, and lock it down with the integrated security bracket.
Retain connectivity
Enjoy easy access to all of your ports with a Sleeve and cutouts designed exclusively for your HP Desktop Mini PC. -
Mix and match
Use this Sleeve with the HP Desktop Mini by itself, or with the PC and an optional storage Expansion Module, HP DM VESA Power Supply Holder Kit that simplifies cable management or HP DM VESA Quick Deploy Adhesive that supports tool-less mounting. -
World-class support
Rest easy with a one-year limited warranty.
- HP Desktop Mini Security / Dual VESA Sleeve - v2 mounting kit - for Desktop Mini - black
- Product Type
- Mounting kit
- Mounting Components
- 4 screws, dual VESA sleeve
- 4.58 cm x 18.1 cm x 16.1 cm
- 411 g
- Recommended Use
- Desktop Mini
- VESA Mounting Interface
- 100 x 100 mm
- Black
- Designed For
- HP 260 G3 (mini desktop), 6300 Pro (micro tower), 6305 Pro (micro tower); EliteDesk 705 G1, 705 G2 (mini desktop), 705 G3 (mini desktop), 705 G5 (mini desktop), 800 G1 (mini desktop), 800 G2 (mini desktop), 800 G3 (mini desktop); ProDesk 400 G1, 400 G2, 400 G3, 400 G5, 405 G4, 600 G2, 600 G3, 600 G4
- 4.58 cm
- 18.1 cm
- 16.1 cm
- 411 g
- Black
AV Furniture
- Mounting kit
- Recommended Use
- Desktop Mini
- 100 x 100 mm
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 59.3 cm x 48.8 cm x 38 cm
- Designed For
- HP 260 G3 (mini desktop) , HP EliteDesk 705 G1 (mini desktop), 705 G2 (mini desktop), 705 G3 (mini desktop), 705 G5 (mini desktop), 800 G1 (mini desktop), 800 G2 (mini desktop), 800 G3 (mini desktop) , HP ProDesk 400 G1 (mini desktop), 400 G2 (mini desktop), 400 G3 (mini desktop), 400 G5 (mini desktop), 405 G4 (mini desktop), 600 G2 (mini desktop), 600 G3 (mini desktop), 600 G4 (mini desktop) , HP Compaq 6300 Pro (micro tower), 6305 Pro (micro tower)
