Fortify your HP Desktop Mini in a range of settings with the HP Desktop Mini LockBox, HP's most secure enclosure for your PC, power brick, and cable connections.
Take your PC security to the max with a durable metal enclosure that’s specifically engineered to protect your HP Desktop Mini PC.
Help deter pulling, tugging or disconnecting cables from the outside with integrated cable routing and clips. Simply remove the protection plate when you need access to front ports and the power button.
Place your PC, power brick, and cable connections inside the enclosure and use the VESA pattern to mount to a flat surface, like a wall or a desk.
After you’ve installed and mounted your system inside the HP Desktop Mini LockBox, add a traditional padlock or an HP UltraSlim Lock for an extra layer of protection.
Compatible with the HP ProDesk 400 G2 DM (Mini); HP EliteDesk 800 G2 35W, 800 G2 65W, HP Collaboration PC G2.
- HP Desktop Mini LockBox - PC enclosure system
- Product Type
- Placing / Mounting
- Wall mountable, under-desk mountable
- Package Content
- Mounting screws
- Jack black
- Product Material
- Metal, mesh
- 27.2 cm x 5.72 cm x 26.8 cm
- 2.391 kg
- Padlock loop, VESA 100 x 100 mm, VESA 75 x 75 mm
- Designed For
- EliteDesk 705 G3 (mini desktop); ProDesk 400 G3 (mini desktop), 600 G2
- Product Type
- Product Material
- Metal, mesh
- Package Content
- Mounting screws
- 27.2 cm
- 5.72 cm
- 26.8 cm
- 2.391 kg
- Jack black
- Designed For
- HP EliteDesk 705 G3 (mini desktop) , HP ProDesk 400 G3 (mini desktop), 600 G2
