Brand
HP Desktop Mini 65w Power Supply Kit
Quicklinx: BCX8WS00 Mfr#: L2X04AA#ABU
Accessory Type: Adapter
£23.53 ex VAT
£28.23 inc VAT
Keep an extra HP Desktop Mini adapter at the ready, or take it with you if you use your HP Desktop Mini on the go with the HP Desktop 65W Mini Power Supply Kit.
  • Compact and easy to use
    Simply connect one end of the adapter to your HP Desktop Mini and plug the other end into a standard outlet. The small size fits easily in a range of settings-on the desk, behind a display or mounted on a wall.
  • World-class support
    Rest easy with a one-year parts replacement limited warranty.
HP - power adapter - 65 Watt
Power adapter - active Power Factor Correction (PFC) - external
English / United Kingdom
Input Voltage
AC 100-240 V
Power Capacity
65 Watt
11.35 cm x 3 cm x 5.5 cm
HP 260 G1 (mini desktop), 260 G3 (mini desktop); Elite Slice (65 Watt), Slice for Meeting Rooms (65 Watt); EliteDesk 705 G3 (mini desktop), 705 G5 (mini desktop), 800 G1 (mini desktop); ProDesk 400 G3 (mini desktop), 400 G4 (mini desktop), 600 G3 (mini desktop), 600 G4 (mini desktop)
Input Voltage
AC 100-240 V
Input Voltage Range
AC 90 - 264 V
Frequency Required
50/60 Hz
Power Capacity
65 Watt
Efficiency
87%
11.35 cm
3 cm
5.5 cm
HP 260 G1 (mini desktop), 260 G2 (mini desktop), 260 G3 (mini desktop), 260 G4 , HP Elite Slice, Slice for Meeting Rooms, Slice G2 with Intel Unite , HP EliteDesk 705 G2 (mini desktop), 705 G3 (mini desktop), 705 G5, 800 G1 (mini desktop) , HP ProDesk 400 G1 (mini desktop), 400 G2 (mini desktop), 400 G3 (mini desktop), 400 G4 (mini desktop), 600 G1 (mini desktop), 600 G3 (mini desktop), 600 G4 (mini desktop)
Brand: HP
