HP Deskjet 4130e AIO
Quicklinx: GW0PWS00 Mfr#: 26Q93B#687
All the features. All the value. Print, scan, and copy, and get a 35 page auto feeder. Count on simple setup[1] and worry-free wireless.[2] Choose HP+ at setup to receive 9 months of Instant Ink [3] and an extended (up to 2 years) HP warranty.[4]
Added extras so you can do more Work fast and hands-free – the 35 page auto feeder helps you complete scan and copy jobs quickly. Easily print, scan, and copy everyday documents from your smartphone, using HP Smart app.[1] Get better range and faster, more reliable connections using dual-band Wi-Fi® with self-reset.[2] Get connected with Bluetooth® and start printing fast from your smartphone or tablet – easy setup.[3]
Simple setup. Simple printing.
Get started fast with simple setup that guides you through each step, using HP Smart app.[1] Easily handle tasks and get a lot from one device – print, scan, and copy. Get quick and easy printing directly at the control panel. This printer is made from recycled printers and other electronics – more than 20% by weight of plastic.
Never run out of ink with Instant Ink[4]
Never run out of ink.[4] Convenient ink cartridge replacements and smart delivery included. Save up to 70% with Instant Ink.[5] Enroll to get ink, delivery and recycling starting at £0.99 a month. Peace of mind with plan flexibility to change or cancel anytime at no cost.[6] Help us put plastic back into printers with prepaid recycling service included.[7]
With HP+, get HP’s simplest printing solution and more value with exclusive use of Original HP Ink. Opt in to HP+ during printer setup to get 9 months of Instant Ink[10] and an extra year of HP warranty (up to 2 years).[4] A cloud-connected HP+ printer is smarter - it keeps itself up to date and ready to print.[8] Never run out of ink and save up to 70% with Instant Ink. 9 months included with HP+.[3,6,7] Print and scan from the palm of your hand. Enjoy advanced productivity features for 2 years with HP+.[1] HP+ requires an HP account, ongoing internet connection, and use of Original HP ink cartridges.
  • Hands-free. Auto-fed
    Work fast and hands-free – the 35 page auto-feeder helps you complete scan and copy jobs quickly.
  • Seamless setup
  • Your reliable connection
    Get better range and faster, more reliable connections using dual-band Wi-Fi with self-reset.
  • Print, scan, and copy from your phone
    With HP Smart app, print everyday documents, get high-quality scanning and sharing, and easily make copies – all from your phone.
  • HP+, the cloud-connected, smart printing system
    An HP+ printer is ready when you are, more secure and productive than ever.
  • Tackle the essentials
    Get versatile performance and print, scan, and copy.
HP Deskjet 4130e All-in-One - multifunction printer - colour - HP Instant Ink eligible
Multifunction printer
United Kingdom, Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
100 - 300 pages
Max Copying Speed
Up to 6 ppm (mono) / up to 3 ppm (colour)
Max Copying Resolution
Up to 300 x 300 dpi (mono) / up to 300 x 300 dpi (colour)
Max Printing Speed
Up to 8.5 ppm (mono) / up to 5.5 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
14.4 Kbps
Scanning
1200 x 1200 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, labels, photo paper
Standard Media Capacity
60 sheets
Max Media Capacity
60 sheets
Output Trays Capacity
25 sheets
Connection Availability
USB 2.0, Wi-Fi(n), Bluetooth 4.2
AirPrint Enabled
Office Machine Features
Print from mobile devices, scan to PDF, HP+ enabled
AC 120/230 V (50/60Hz)
42.8 cm x 33.2 cm x 20 cm
4.82 kg
Enclosure Colour
Indigo
Environmental Standards
EPEAT Silver
1-year warranty
Printing Technology
Ink-jet - colour
1000 pages
100 - 300 pages
Display Features
LCD display
AirPrint Enabled
Enclosure Colour
Indigo
Standard Memory
84 MB
Max Supported Memory
84 MB
Copying
Max Copying Speed
Maximum Copies
9
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
328 nozzles (black), 588 nozzles (colour)
Max Printing Speed
Ink Cartridge Configuration
1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3 GUI, PCLm, URF
First Print Out Time B/W
15 sec
First Print Out Time Colour
19 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
14.4 Kbps
PC Faxing
Fax Machine Features
Fax forwarding, automatic redialing, Distinctive Ring Detection (DRD), fax polling
Document & Media Handling
Max Original Size
216 x 297 mm
Supported Original Sizes
216 x 297 mm
Original Type
Sheets
35 sheets
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
300 g/m²
Min Media Weight (lb)
16 lbs
Max Media Weight (lb)
145 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 101.6 x 152.4 mm, 76.2 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm
Supported Envelope Sizes
International DL (110 x 220 mm)
60 sheets
Max Media Capacity
60 sheets
25 sheets
ADF - 35 sheets , Input tray - 60 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 300 g/m²; weight (lbs): 16 lbs - 145 lbs , Output tray - 25 sheets
Speed Details
Printing: up to 20 ppm (A4) - B/W draft , Printing: up to 16 ppm (A4) - colour draft , Printing: up to 8.5 ppm (A4) - B/W (ISO) , Printing: up to 5.5 ppm (A4) - colour (ISO) , Copying: up to 6 ppm - B/W (ISO) , Copying: up to 3 ppm - colour (ISO) , Scanning: up to 2.5 ppm (A4) - B/W (200 dpi) , Scanning: up to 2.5 ppm (A4) - colour (200 dpi) , Scanning: up to 2.5 ppm (Letter A) - B/W (200 dpi) , Scanning: up to 2.5 ppm (Letter A) - colour (200 dpi)
1 x USB 2.0 - 4 pin USB Type B
Software Included
Drivers & Utilities, HP Smart App
Power Consumption Sleep
1.1 Watt
Consumables Included
1 x ink cartridge (black) - HP 67 , 1 x ink cartridge (yellow/cyan/magenta) - HP 67
FCC Class B certified, FCC CFR47 Part 15, EN 62479:2010, EN 61000-3-3:2013, CISPR 24:2010, IEC 61000-3-3:2013, EN 55024:2010, EN 62311:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, EN 55032:2015, ICES-003 issue 6 Class B, EN 301 489-17 V3.1.1 (2017), CISPR 35, CISPR 32:2015 Class B, EN 301 489-1 V2.1.1:2017, EN 55035:2017, EN 62368-1:2014+A11:2017, IEC 61000-3-2:2014, IEC 62368-1: 2014, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
EPEAT Compliant
EPEAT Silver
Limited warranty - 1 year
42.8 cm
33.2 cm
20 cm
4.82 kg
Shipping Width
47.5 cm
Shipping Depth
24.2 cm
Shipping Height
40.5 cm
Shipping Weight
6.19 kg
Sound Emission
56 dBA (operating)
5 °C
15 - 80% (non-condensing)
Ink (5)
GW0P HP 305XL High yeild black orginal In Stock £16.08
GW0P HP 305 Black Original Ink Cartridge In Stock £8.68
GW0P HP 305 Colour (Cyan, Magenta, Yellow) Original Ink Cartridge In Stock £8.81
GW0P HP 305XL High Yield Tri-Color Origin In Stock £14.73
GW0P HP HP 305 2-PACK TRI-COLOR/BLACK In Stock £16.78
Other bundles (1)
GW0P HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £17.00
