HP Deskjet 3630 All-in-One Colour InkJet Multifunction Printer
WAS £36.06, NOW UNDER £21.00!
Clearance
Exclusive
Price Drop
Quicklinx: BQ85WS00 Mfr#: K4T99B#BEV
Keep it simple with an affordable all-in-one you can count on. Stay connected with the easiest way to print from your smartphone or tablet. Quickly print, scan, and copy – right out of the box – and keep free of clutter with a space-saving design.
  • Recycle today for a better tomorrow
    Easily recycle your Original HP ink and toner cartridges for free.
  • Easy mobile printing from HP
    Easily print from your smartphone, tablet, and notebook at work, home or on the go.
  • Remote control for your printer
    Manage your all-in-one or MFP from your smartphone or tablet, using the HP All-in-One Printer Remote app.
  • On-the-go printing with HP ePrint
    Print photos, documents and more when you're on the go, using HP ePrint.
  • Borderless printing
    Borderless photos are printed right to the edge of the paper. You get beautiful photo prints with no trimming!
HP Deskjet 3630 All-in-One - multifunction printer - colour
Multifunction printer
English / United Kingdom, Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
100 - 250 pages
Max Copying Speed
Up to 5 ppm (mono) / up to 3.5 ppm (colour)
Max Copying Resolution
Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour)
Max Printing Speed
Up to 8.5 ppm (mono) / up to 6 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Automatic paper sensor, Mobile Printing
AC 120/230 V (50/60Hz)
43.8 cm x 31 cm x 15.8 cm
4.17 kg
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Ink-jet - colour
1000 pages
100 - 250 pages
Display Features
7 segment LCD display with icons
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Copying
Max Copying Speed
Max Document Enlargement
200%
Max Document Reduction
25%
Maximum Copies
9
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3 GUI, PCLm, URF
Scanning
Scan Element
CIS
Optical Resolution
1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 76 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm)
Borderless Photo Sizes
A4 (210 x 297 mm)
Input tray - 60 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 300 g/m² , Output tray - 25 sheets
Speed Details
Printing: up to 8.5 ppm (A4) - B/W (ISO) , Printing: up to 6 ppm (A4) - colour (ISO) , Copying: up to 5 ppm (A4) - B/W (ISO) , Copying: up to 3.5 ppm (A4) - colour (ISO)
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits)
Software Included
Drivers & Utilities, HP Photo Creations
10 Watt
Power Consumption Standby
2.1 Watt
Power Consumption Sleep
0.88 Watt
USB cable
Consumables Included
1 x ink cartridge (black) - up to 190 pages - HP 302 , 1 x ink cartridge (yellow/cyan/magenta) - up to 165 pages - HP 302
GOST, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, CISPR 24:2010, EN 55024:2010, CISPR 22:2008, EN 55022:2010 Class B
ENERGY STAR Certified
43.8 cm
31 cm
15.8 cm
4.17 kg
Shipping Width
47.5 cm
Shipping Depth
19.2 cm
Shipping Height
35.4 cm
Shipping Weight
5.09 kg
Sound Emission
47 dBA (operating)
5 °C
20 - 80%
BQ85 HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £16.53
