HP Deskjet 2721e AIO
Quicklinx: GVW2WS00 Mfr#: 26K68B#687
All the basics, now with easy-to-use features. Print, scan, copy, simple setup with HP Smart app and worry-free wireless. Choose HP+ and get the smart printing system that keeps you connected and ready to print from virtually anywhere.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
  • Seamless setup
    Get started fast with simple setup that guides you through each step, using HP app.
  • Your reliable connection
    Get better range and faster, more reliable connections using dual-band Wi-Fi with self-reset.
  • Printing from your smartphone just got easier
    Easily print everyday documents from your smartphone, using HP app.
  • Amazing scanning, now on your smartphone
    With HP app, get high-quality scanning and sharing – plus easily make copies – from your smartphone.
  • Tackle the essentials
    Get versatile performance and print, scan, and copy.
  • HP+, the cloud-connected, smart printing system
    An HP+ printer is ready when you are, more secure and productive than ever.
HP Deskjet 2721e All-in-One - multifunction printer - colour - HP Instant Ink eligible
Multifunction printer
United Kingdom, Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
50 - 100 pages
Max Copying Speed
Up to 6 ppm (mono) / up to 3 ppm (colour)
Max Printing Speed
Up to 7.5 ppm (mono) / up to 5.5 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 x 1200 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
89 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, labels, photo paper
Standard Media Capacity
60 sheets
Max Media Capacity
60 sheets
Output Trays Capacity
25 sheets
Connection Availability
USB 2.0, Bluetooth, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Print from mobile devices, scan to PDF
AC 230 V (50/60Hz)
42.5 cm x 30.4 cm x 15.4 cm
3.42 kg
Enclosure Colour
Indigo
Printing Technology
Ink-jet - colour
1000 pages
50 - 100 pages
Display Features
Icon LCD display
AirPrint Enabled
Enclosure Colour
Indigo
Copying
Max Copying Speed
Maximum Copies
9
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
328 nozzles (black), 588 nozzles (colour)
Max Printing Speed
Ink Cartridge Configuration
1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3 GUI, PCLm, URF
First Print Out Time B/W
15 sec
First Print Out Time Colour
19 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Min Media Size
89 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 89 x 127 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm)
60 sheets
Max Media Capacity
60 sheets
25 sheets
Input tray - 60 sheets size: 89 x 127 mm - A4 (210 x 297 mm) weight: 60 g/m² - 300 g/m² , Output tray - 25 sheets
Speed Details
Printing: up to 20 ppm (A4) - B/W draft , Printing: up to 16 ppm (A4) - colour draft , Printing: up to 7.5 ppm - B/W (ISO) , Printing: up to 5.5 ppm - colour (ISO) , Copying: up to 6 ppm - B/W (ISO) , Copying: up to 3 ppm - colour (ISO)
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
MS Windows 7 (32/64 bits), Windows 10 (32/64-bits), macOS 10.13, macOS 10.14, macOS 10.15
Software Included
Drivers & Utilities, HP Smart App
AC 230 V (50/60Hz)
Power Consumption Standby
2.5 Watt
Power Consumption Sleep
1.1 Watt
FCC CFR47 Part 15 B, EN 62479:2010, EN 61000-3-3:2013, CISPR 24:2010, IEC 61000-3-3:2013, EN 55024:2010, EN 62311:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, EN 55032:2015, ICES-003 issue 6 Class B, EN 301 489-17 V3.1.1 (2017), CISPR 32:2015 Class B, EN 301 489-1 V2.1.1:2017, EN 55035:2017, EN 62368-1:2014+A11:2017, IEC 61000-3-2:2014, IEC 62368-1: 2014, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, EN 300 328 V2.1.1:2016, CISPR 35: 2016, EN 301 893 V2.2.1:2017
42.5 cm
30.4 cm
15.4 cm
3.42 kg
Shipping Width
47.5 cm
Shipping Depth
19.1 cm
Shipping Height
35.4 cm
Shipping Weight
4.58 kg
Sound Emission
48 dBA (operating)
5 °C
Ink (4)
GVW2 HP 305XL High yeild black orginal In Stock £17.36
GVW2 HP 305 Black Original Ink Cartridge In Stock £9.23
GVW2 HP 305 Colour (Cyan, Magenta, Yellow) Original Ink Cartridge In Stock £9.23
GVW2 HP 305XL High Yield Tri-Color Origin In Stock £15.90
Other bundles (1)
GVW2 HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £17.30
