HP Deskjet 2540 Colour InkJet Multifunction Printer
Quicklinx: 8YZ6WS00 Mfr#: A9U22B#BHC
Enjoy easy wireless printing from any room – plus scanning and copying too – with this simple and affordable HP Deskjet all-in-one. Save space with a compact design that fits anywhere and get started in no time with quick and easy setup.
  • Unleash your printing
    Print wirelessly from your mobile device without a Wi-Fi code or password.
  • 2-sided printing
    Allows you to print on both sides of the page, cutting your paper use by up to 50%.
HP Deskjet 2540 All-in-One - multifunction printer - colour
Multifunction printer
United Kingdom, Ireland, Nordics, Baltic Region
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 impressions
Recommended Monthly Volume
300 - 400 pages
Max Copying Speed
Up to 4.5 ppm (mono) / up to 3 ppm (colour)
Max Copying Resolution
Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour)
Max Printing Speed
Up to 7 ppm (mono) / up to 4 ppm (colour)
Max Printing Resolution
Up to 600 x 600 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 x 1200 dpi
Display
1.4"
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Standard Media Capacity
60 sheets
Output Trays Capacity
25 sheets
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Scan to folder, HP Auto Wireless Connect
AC 120/230 V (50/60Hz)
42.523 cm x 55.219 cm x 25.219 cm
3.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
EPEAT Bronze, ENERGY STAR Qualified
Printing Technology
Ink-jet - colour
1000 impressions
300 - 400 pages
Display Diagonal Size
1.4"
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Copying
Max Copying Speed
Maximum Copies
5
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
First Print Out Time B/W
17 sec
First Print Out Time Colour
24 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
300 g/m²
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Supported Envelope Sizes
International DL (110 x 220 mm)
60 sheets
25 sheets
Input tray - 60 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 300 g/m² , Output tray - 25 sheets
Speed Details
Printing: up to 7 ppm - B/W (ISO) , Printing: up to 4 ppm - colour (ISO) , Copying: up to 4.5 ppm - B/W (ISO) , Copying: up to 3 ppm - colour (ISO)
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), Apple Mac OS X 10.6, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit
Software Included
Drivers & Utilities
10 Watt
Power Consumption Standby
2 Watt
Power Consumption Sleep
0.9 Watt
USB cable
FCC Class B certified, GOST, CISPR 22 Class B, CISPR 24, EN55022 Class B, FCC CFR47 Part 15, LVD, IEC 60950-1 Second Edition, EN 61000-3-3:2008, ICES-003 issue 4 Class B, EN 61000-3-2:2006+A1:2009+A2:2009, EN 60950-1:2006
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
42.523 cm
55.219 cm
25.219 cm
3.6 kg
Shipping Width
46.3 cm
Shipping Depth
35.4 cm
Shipping Height
19.3 cm
Shipping Weight
5.2 kg
5 °C
15 - 85% (non-condensing)
Ink (2)
8YZ6 HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £16.41
8YZ6 HP 301XL High Yield Tri-colour Original Ink Cartridge In Stock £33.42
Other bundles (1)
8YZ6 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.02
