Make your everyday printing, scanning and copying easy with an HP DeskJet all-in-one that simply works – right out of the box. Save money with optional high-yield ink cartridges. Plus, save space with an all-in-one designed to fit where you need it.
Get just what you need – right away
Count on easy versatility. Print, scan and copy what you need quickly with a reliable all-in-one. -
It's easy from the start
Get started in fewer steps. Easily set up this all-in-one to print, scan and copy with simple controls.Save your space with a compact all-in-one designed to fit on your desk, on a shelf or anywhere you need it. -
Tackle more tasks affordably
Print more for less, using the world's No. 1 printer brand plus Original HP ink cartridges.Full of value – print up to twice as many pages with Original HP high-yield ink cartridges. -
Reduce your impact
Conserve resources without sacrificing performance with an all-in-one that's ENERGY STAR certified.Reduce your environmental impact – count on easy, free cartridge recycling through HP Planet Partners.
- HP Deskjet 2130 All-in-One - multifunction printer - colour
- Multifunction printer
- Localisation
- English / United Kingdom, Ireland
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 1000 pages
- Recommended Monthly Volume
- 50 - 200 pages
- Max Copying Speed
- Up to 5 ppm (mono) / up to 3 ppm (colour)
- Max Copying Resolution
- Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour)
- Max Printing Speed
- Up to 7.5 ppm (mono) / up to 5.5 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Scanning
- 1200 dpi
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- 89 x 127 mm (min) - A4 (210 x 297 mm), 215 x 279 mm (max)
- Media Type
- Plain paper, photo paper
- Standard Media Capacity
- 60 sheets
- Output Trays Capacity
- 25 sheets
- Connection Availability
- Interface
- USB 2.0
- Power
- AC 120/230 V (50/60Hz)
- 42.5 cm x 30.4 cm x 14.9 cm
- 3.42 kg
- Environmental Standards
- ENERGY STAR Qualified
- Ink-jet - colour
- 1000 pages
- 50 - 200 pages
- Interface
- USB 2.0
- Localisation
Copying
- Max Copying Speed
- Maximum Copies
- 9
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- Min Media Size
- 89 x 127 mm
- Max Media Size
- A4
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 215 x 279 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm)
- 60 sheets
- 25 sheets
- Input tray - 60 sheets size: 89 x 127 mm - A4 (210 x 297 mm) weight: 60 g/m² - 300 g/m² , Output tray - 25 sheets
- Speed Details
- Printing: up to 7.5 ppm - B/W (ISO) , Printing: up to 5.5 ppm - colour (ISO) , Copying: up to 5 ppm - B/W (ISO) , Copying: up to 3 ppm - colour (ISO) , Printing: up to 20 ppm (A4) - B/W draft , Printing: up to 16 ppm (A4) - colour draft , Printing: up to 16 ppm (10 x 15 cm (4"x6")) - photo draft , Printing: 66 sec (10 x 15 cm (4"x6")) - photo normal , Printing: up to 20 ppm (Letter A) - B/W draft , Printing: up to 16 ppm (Letter A) - colour draft
- 1 x USB 2.0 - 4 pin USB Type B
- Operating System Support
- Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits)
- Software Included
- Drivers & Utilities
- Voltage Required
- 10 Watt
- Power Consumption Standby
- 1.9 Watt
- Power Consumption Sleep
- 9 Watt
- Consumables Included
- 1 x ink cartridge (black) - up to 190 pages - HP 302 , 1 x ink cartridge (yellow/cyan/magenta) - up to 165 pages - HP 302
- EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EAC, CISPR 24:2010, EN 55024:2010, CISPR 22:2008, EN 55022:2010 Class B
- ENERGY STAR Certified
- 42.5 cm
- 30.4 cm
- 14.9 cm
- 3.42 kg
- Shipping Width
- 47.5 cm
- Shipping Depth
- 19.1 cm
- Shipping Height
- 35.4 cm
- Shipping Weight
- 4.48 kg
- Sound Emission
- 48 dBA (operating)
- 5 °C
- 40 °C
- 20 - 80%
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £16.36 |
