HP DeskJet 1510 AiO Printer
Quicklinx: 9HFRWS00 Mfr#: B2L56B#620
Print, scan and copy everyday documents with this simple and affordable HP Deskjet all-in-one. Save space with a compact design that fits anywhere and get started in no time with quick and easy setup.
  • Print, scan and copy with one affordable device
    Enjoy real versatility – produce everything you need with this no-fuss all-in-one.Do it all from one affordable device – print web pages, scan photos, copy correspondence and more.Print and copy with laser-quality text and vivid colour graphics using affordable HP ink cartridges.Get up to 2.5x more black printed pages and 2x more colour printed pages with optional high-capacity ink cartridges.
  • Get started straightaway with quick, easy set-up and intuitive operation
    No waiting – installs right out of the box in just a few minutes.Print, scan and copy with an all-in-one designed for simple operation – just four buttons.Get performance you can rely on with HP Deskjet – the world's No.1 printer brand.Start even faster on HP PCs running Windows 8.
  • Save space with a sleek, stylish and compact design
    Save valuable space with a compact all-in-one that's designed fit almost anywhere.Keep it close to hand on your desk, or neatly out of the way on a shelf.Conserve energy – and save money – with this ENERGY STAR qualified printer.
HP Deskjet 1510 All-in-One - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
300 - 400 pages
Max Copying Speed
Up to 4.5 ppm (mono) / up to 3 ppm (colour)
Max Copying Resolution
Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour)
Max Printing Speed
Up to 7 ppm (mono) / up to 4 ppm (colour)
Max Printing Resolution
Up to 600 x 600 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 x 2400 dpi
Original Size
216 x 297 mm (max)
Media Size
89 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, greeting cards, photo paper
Standard Media Capacity
60 sheets
Output Trays Capacity
25 sheets
Connection Availability
USB 2.0
AC 110/230 V (50/60Hz)
42.523 cm x 30.582 cm x 15.66 cm
3.6 kg
Environmental Standards
EPEAT Bronze, ENERGY STAR Qualified
Printing Technology
Ink-jet - colour
1000 pages
300 - 400 pages
USB 2.0
Copying
Max Copying Speed
Maximum Copies
9
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
First Print Out Time B/W
17 sec
First Print Out Time Colour
24 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Min Media Size
89 x 127 mm
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 101.6 x 152.4 mm, 89 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm, 215 x 279 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm)
60 sheets
25 sheets
Input tray - 60 sheets - Legal (216 x 356 mm) , Output tray - 25 sheets
Speed Details
Printing: up to 7 ppm - B/W (ISO) , Printing: up to 4 ppm - colour (ISO) , Printing: up to 20 ppm - B/W draft , Printing: up to 16 ppm - colour draft , Copying: up to 4 ppm - B/W draft , Copying: up to 2 ppm - colour draft , Copying: up to 4.5 ppm - B/W (ISO) , Copying: up to 3 ppm - colour (ISO)
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
MS Windows 7, MS Windows XP SP3, MS Windows Vista, Apple Mac OS X 10.6, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8
Software Included
Drivers & Utilities
10 Watt
Power Consumption Standby
2 Watt
Power Consumption Sleep
0.9 Watt
CISPR 24, CISPR 22, IEC 60950-1, FCC CFR47 Part 15 B, LVD, EN 61000-3-3:2008, ICES-003 issue 4 Class B, NOM-019-SCFI-1993 IRAM, EN 61000-3-2:2006+A1:2009+A2:2009
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
42.523 cm
30.582 cm
15.66 cm
3.6 kg
Shipping Width
46.3 cm
Shipping Depth
35.4 cm
Shipping Height
19.3 cm
Shipping Weight
5.2 kg
Sound Emission
54 dBA (operating)
5 °C
15 - 80% (non-condensing)
9HFR HP 301XL High Yield Tri-colour Original Ink Cartridge In Stock £34.16
