Print and share everyday documents with this reliable HP printer. This easy-to-use printer is compact, affordable and helps you conserve resources.
Enjoy easy set-up and reliable performance from a printer you can trust:
- Get started straightaway - easy-to-use and installs right out of the box in just a few minutes.
- No waiting around - this quick-response printer powers up in seconds; save time with instant shut-down too.
- Get peace of mind with the one-year limited warranty plus HP Total Care advice and support.
- Be sure of reliable performance from the world's top-selling printer brand.
Print everyday documents with HP's most straightforward and affordable printer:
- Produce everyday documents with laser-quality text and vivid colour graphics.
- Get great print quality with affordable HP ink cartridges.
- Trust HP Deskjet - celebrating more than 20 years as the world's top-selling printer brand.
- Get more printed pages with optional high-capacity XL ink cartridges (not included, please purchase separately).
Reduce energy consumption and conserve resources - designed with the environment in mind:
- Conserve energy - and save money - with this ENERGY STAR® qualified printer.
- New, low-consumption design cuts energy use in half compared with previous products.
- Save resources - this HP Deskjet printer is made of 30 percent recycled plastics.
- Easily recycle HP Deskjet packaging - this product is shipped in 99% recyclable packaging.
- Get free, easy recycling - cartridges returned through HP Planet Partners are recycled responsibly.
Designed with the environment in mind - created from 30% recycled plastic.
Recycle or reuse 99% of packaging - including a reusable bag. - Some small pieces of tape are not recyclable.
Low energy: sleep mode is comparable with powering a clock radio.
ENERGY STAR® qualified product
Box Contains:
- HP Deskjet 1000 Printer
- HP 301 Black Ink Cartridge
- HP 301 Tri-colour Ink Cartridge
- HP software CD
- Setup guide, reference guide
- Power supply and cord
- Reusable bag
Get started straightaway – easy-to-use and installs right out of the box in just a few minutes.No waiting around – this quick-response printer powers up in seconds; save time with instant shut-down too.Get peace of mind with the one-year limited warranty plus HP Total Care advice and support.Be sure of reliable performance from the world's top-selling printer brand. -
Produce everyday documents with laser-quality text and vivid colour graphics.Get great print quality with affordable HP ink cartridges.Trust HP Deskjet – celebrating more than 20 years as the world's top-selling printer brand.Get up to 2.5x more black printed pages and 2x more colour printed pages with optional high-capacity ink cartridges. -
Reduce energy consumption and conserve resources – designed with the environment in mind
Conserve energy – and save money – with this ENERGY STAR qualified printer.New, low-consumption design cuts energy use in half compared with previous products.Save resources – this HP Deskjet printer is made of 30 percent recycled plastics.Get free, easy recycling – cartridges returned through HP Planet Partners are recycled responsibly.
- HP Deskjet 1000 - printer - colour - ink-jet
- Printer Type
- Personal printer - ink-jet - colour
- 2 kg
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Print Speed
- Up to 16 ppm - black draft - A4 (210 x 297 mm) , Up to 12 ppm - colour draft - A4 (210 x 297 mm) , Up to 5.5 ppm - black best - A4 (210 x 297 mm) , Up to 4 ppm - colour best - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 600 dpi
- Max Resolution (Colour)
- 4800 x 1200 dpi
- Interface
- USB
- Language Simulation
- PCL 3
- Media Type
- Envelopes, transparencies, labels, iron-on transfers, cards
- Total Media Capacity
- 60 sheets
- Monthly Duty Cycle (max)
- 1000 pages
- System Requirements
- Microsoft Windows 7, Microsoft Windows XP SP2 or later, Microsoft Windows Vista, Apple MacOS X 10.6, Apple MacOS X 10.5
- Microsoft Certification
- Compatible with Windows 7
- 42.1 cm x 38 cm x 26.6 cm
- Printer Type
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB
- 600 dpi
- 4800 x 1200 dpi
- PCL 3
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
- Media Weight
- 75 g/m² - 280 g/m²
- 60 sheets
- Output Trays Capacity
- 25 sheets
Duty Cycle
- 1000 pages
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x ink cartridge (yellow/cyan/magenta) - up to 165 pages - HP 301 , 1 x ink cartridge (black) - up to 190 pages - HP 301
- Power Device
- Power adapter - external
- Frequency Required
- 50/60 Hz
- 10 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- 5 °C
- 40 °C
- 5 - 80%
- 42.1 cm
- 38 cm
- 26.6 cm
- 2 kg
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £16.41 |
