No need to make trade-offs with this, the fastest printer in its class. The HP DesignJet Z6200 Photo Production Printer-a workhorse in disguise-enables you to offer outstanding photo image quality. Become a trusted partner with HP technologies.
Designed for speed and productivity
Print as fast as 113 m²/hr (1225 ft²/hr) in Fast mode and 16.4 m²/hr (177 ft²/hr) in Normal mode
Create quality prints at top speed with HP Double Swath Technology and the HP Optical Media Advance Sensor
Gain time—you can handle all your prints immediately using fastdrying HP Vivid Photo Inks
Unrivalled image quality
Do more—produce backlit signs, POP displays, roll-up banners, canvases, line drawings, and maps with unrivalled print quality
Create unique black-and-white prints—three shades of black HP inks produce outstanding optical density and smooth transitions
Offer exceptional colors—HP Vivid Photo Inks include chromatic red for a wide color gamut, with uniform gloss
Advanced color management backed by HP reliability
See reliable results with HP Professional PANTONE® color emulation and Adobe Postscript®/PDF Upgrade Kit
Generate custom ICC profiles and achieve color accuracy, consistency with the embedded spectrophotometer
Boost color accuracy—complete coverage of SWOP, ISO, GRACOL, 3DAP, EUROSCALE, TOYO, and FOGRA gamut
Print as fast as 113 m /hr (1225 ft /hr) in Fast mode and 16.4 m /hr (177 ft /hr) in Normal mode.Create quality prints at top speed with HP Double Swath Technology and the HP Optical Media Advance Sensor.Gain time-you can handle all your prints immediately using fastdrying HP Vivid Photo Inks.Optimize performance and ink usage-automatic servicing routines help prevent nozzle clogging and media waste. -
Do more-produce backlit signs, POP displays, roll-up banners, canvases, line drawings, and maps with unrivalled print quality.Create unique black-and-white prints-three shades of black HP inks produce outstanding optical density and smooth transitions.Offer exceptional colors-HP Vivid Photo Inks include chromatic red for a wide color gamut, with uniform gloss.Provide extraordinary display permanence-durable prints last up to 200 years. -
See reliable results with HP Professional PANTONE color emulation and Adobe Postscript /PDF Upgrade Kit.Generate custom ICC profiles and achieve color accuracy, consistency with the embedded spectrophotometer.Boost color accuracy-complete coverage of SWOP, ISO, GRACOL, 3DAP, EUROSCALE, TOYO, and FOGRA gamut.Streamline production with an HP Embedded Web Server and print previews, which help eliminate trial and error.
- HP DesignJet Z6200 - large-format printer - colour - ink-jet
- Printer Type
- 42" large-format printer - ink-jet - colour
- 123 kg
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- Light cyan, magenta, light magenta, yellow, red, green, blue, light grey, grey, photo black, matte black, gloss enhancer
- Min Media Size (Custom)
- 280 mm
- Max Media Size (Custom)
- 1067 mm
- Print Speed
- Up to 140 sq.m/hour - mixed text/colour graphics draft
- Max Resolution (B&W)
- 2400 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Interface
- USB, Gigabit LAN
- Hard Drive
- 160 GB
- Language Simulation
- HP RTL, CALS G4, HP GL/2
- Media Type
- Coated paper, photo paper, fabric, bond paper, proofing paper, banner paper, film, backlit paper
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
- System Requirements
- Linux, Microsoft Windows, Microsoft Windows 7, Apple MacOS X 10.6, Apple MacOS X 10.5
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 197 cm x 69 cm x 137 cm
- Printer Type
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Ink Type
- HP Vivera Inks
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB, Gigabit LAN
- 2400 x 1200 dpi
- 2400 x 1200 dpi
- PostScript Support
- Optional
Storage
- Hard Drive
- 160 GB
Media Handling
- Media Type
- 280 mm
- 1067 mm
- Media Weight
- 460 g/m²
- Networking
- Print server
- Data Link Protocol
- Expansion Slots
- 1 x EIO , Memory
- Connections
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0
- CSA, VCCI, GOST, CCC, EMC, PSB, EN 60950-1, KCC, WEEE, ICES, REACH
- Power Device
- Power supply
- Frequency Required
- 50/60 Hz
- 420 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year
- 5 °C
- 40 °C
- 20 - 80%
- 197 cm
- 69 cm
- 137 cm
- 123 kg
- Width (Shipping)
- 223 cm
- Depth (Shipping)
- 75 cm
- Height (Shipping)
- 120 cm
- Weight (Shipping)
- 210 kg
HP Universal Bond Paper-610 mm x 45.7 m (24in x 150ft) | In Stock | £11.46 |
HP Universal Bond Paper-1067 mm x 45.7 m (42in x 150ft) | In Stock | £19.51 |
HP Bright White Inkjet Paper-841 mm x 45.7 m (33.11in x 150ft) | In Stock | £23.56 |
HP Universal Bond Paper-914 mm x 45.7 m (36in x 150ft) | In Stock | £14.92 |
HP Bright White Inkjet Paper-594 mm x 45.7 m (23.39in x 150ft) | In Stock | £16.46 |
HP 771 Designjet Maintenance Cartridge | In Stock | £66.32 |
HP Universal Bond Paper-594 mm x 91.4 m | In Stock | £21.71 |
HP 771 Light Magenta/Light Cyan Designjet Printhead | In Stock | £150.81 |
HP 771 Photo Black/Light Gray Designjet Printhead | In Stock | £150.81 |
HP 771 Matte Black/Chromatic Red Designjet Printhead | In Stock | £150.81 |
HP 771C 775-ml Matte Black Designjet Ink Cartridge | In Stock | £190.70 |
HP 771C 775-ml Photo Black Designjet Ink Cartridge | In Stock | £190.70 |
HP 771C 775-ml Chromatic Red Designjet Ink Cartridge | In Stock | £190.70 |
HP 771C 775-ml Light Cyan Designjet Ink Cartridge | In Stock | £190.70 |
HP 771C 775-ml Yellow Designjet Ink Cartridge | In Stock | £190.70 |
HP 771C 775-ml Light Magenta Designjet Ink Cartridge | In Stock | £190.70 |
HP 771C 775-ml Magenta Designjet Ink Cartridge | In Stock | £190.70 |
HP 771C 775-ml Light Gray Designjet Ink Cartridge | In Stock | £190.70 |
HP Ink Gloss Photo PPR 235GSM 24X30.5M | In Stock | £59.74 |
HP Coated Paper-610 mm x 45.7 m (24in x 150ft) | In Stock | £29.82 |
HP Bright White Inkjet Paper-914 mm x 45.7 m | In Stock | £24.94 |
HP Bright White Inkjet Paper-610 mm x 45.7 m | In Stock | £16.36 |
HP Coated Paper-914 mm x 45.7 m (36in x 150ft) | In Stock | £41.91 |
HP Coated Paper-1067 mm x 45.7 m (42in x 150ft) | In Stock | £55.96 |
