HP DesignJet Z6200 42" Large Format Printer
Quicklinx: CP0TWS00 Mfr#: CQ109A#B19
No need to make trade-offs with this, the fastest printer in its class. The HP DesignJet Z6200 Photo Production Printer-a workhorse in disguise-enables you to offer outstanding photo image quality. Become a trusted partner with HP technologies.
Designed for speed and productivity
Print as fast as 113 m²/hr (1225 ft²/hr) in Fast mode and 16.4 m²/hr (177 ft²/hr) in Normal mode
Create quality prints at top speed with HP Double Swath Technology and the HP Optical Media Advance Sensor
Gain time—you can handle all your prints immediately using fastdrying HP Vivid Photo Inks
Unrivalled image quality
Do more—produce backlit signs, POP displays, roll-up banners, canvases, line drawings, and maps with unrivalled print quality
Create unique black-and-white prints—three shades of black HP inks produce outstanding optical density and smooth transitions
Offer exceptional colors—HP Vivid Photo Inks include chromatic red for a wide color gamut, with uniform gloss
Advanced color management backed by HP reliability
See reliable results with HP Professional PANTONE® color emulation and Adobe Postscript®/PDF Upgrade Kit
Generate custom ICC profiles and achieve color accuracy, consistency with the embedded spectrophotometer
Boost color accuracy—complete coverage of SWOP, ISO, GRACOL, 3DAP, EUROSCALE, TOYO, and FOGRA gamut
  • Designed for speed and productivity
    Print as fast as 113 m /hr (1225 ft /hr) in Fast mode and 16.4 m /hr (177 ft /hr) in Normal mode.Create quality prints at top speed with HP Double Swath Technology and the HP Optical Media Advance Sensor.Gain time-you can handle all your prints immediately using fastdrying HP Vivid Photo Inks.Optimize performance and ink usage-automatic servicing routines help prevent nozzle clogging and media waste.
  • Unrivalled image quality
    Do more-produce backlit signs, POP displays, roll-up banners, canvases, line drawings, and maps with unrivalled print quality.Create unique black-and-white prints-three shades of black HP inks produce outstanding optical density and smooth transitions.Offer exceptional colors-HP Vivid Photo Inks include chromatic red for a wide color gamut, with uniform gloss.Provide extraordinary display permanence-durable prints last up to 200 years.
  • Advanced color management backed by HP reliability
    See reliable results with HP Professional PANTONE color emulation and Adobe Postscript /PDF Upgrade Kit.Generate custom ICC profiles and achieve color accuracy, consistency with the embedded spectrophotometer.Boost color accuracy-complete coverage of SWOP, ISO, GRACOL, 3DAP, EUROSCALE, TOYO, and FOGRA gamut.Streamline production with an HP Embedded Web Server and print previews, which help eliminate trial and error.
HP DesignJet Z6200 - large-format printer - colour - ink-jet
Printer Type
42" large-format printer - ink-jet - colour
123 kg
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
Light cyan, magenta, light magenta, yellow, red, green, blue, light grey, grey, photo black, matte black, gloss enhancer
Min Media Size (Custom)
280 mm
Max Media Size (Custom)
1067 mm
Print Speed
Up to 140 sq.m/hour - mixed text/colour graphics draft
Max Resolution (B&W)
2400 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
USB, Gigabit LAN
Hard Drive
160 GB
Language Simulation
HP RTL, CALS G4, HP GL/2
Media Type
Coated paper, photo paper, fabric, bond paper, proofing paper, banner paper, film, backlit paper
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
Linux, Microsoft Windows, Microsoft Windows 7, Apple MacOS X 10.6, Apple MacOS X 10.5
Microsoft Certification
Compatible with Windows 7
1-year warranty
197 cm x 69 cm x 137 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Ink Type
HP Vivera Inks
Print Speed
Wired
USB, Gigabit LAN
2400 x 1200 dpi
2400 x 1200 dpi
PostScript Support
Optional
Language Simulation
Storage
Hard Drive
160 GB
Media Handling
Media Type
280 mm
1067 mm
Media Weight
460 g/m²
Print server
Expansion Slots
1 x EIO , Memory
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0
CSA, VCCI, GOST, CCC, EMC, PSB, EN 60950-1, KCC, WEEE, ICES, REACH
Power supply
Frequency Required
50/60 Hz
420 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
5 °C
20 - 80%
197 cm
69 cm
137 cm
123 kg
Width (Shipping)
223 cm
Depth (Shipping)
75 cm
Height (Shipping)
120 cm
Weight (Shipping)
210 kg
CP0T HP Universal Bond Paper-610 mm x 45.7 m (24in x 150ft) In Stock £12.09
CP0T HP Heavyweight Coated Paper-914 mm x 30.5 m (36in x 100ft) In Stock £44.76
CP0T HP Universal Bond Paper-1067 mm x 45.7 m (42in x 150ft) In Stock £19.91
CP0T HP Bright White Inkjet Paper-841 mm x 45.7 m (33.11in x 150ft) In Stock £19.40
CP0T HP Universal Bond Paper-914 mm x 45.7 m (36in x 150ft) In Stock £15.89
CP0T HP Premium Instant-dry Satin Photo Paper-610 mm x 22.9 m (24in x 75ft) In Stock £76.16
CP0T HP Premium Instant-dry Satin Photo Paper In Stock £142.99
CP0T HP Bright White Inkjet Paper-594 mm x 45.7 m (23.39in x 150ft) In Stock £15.06
CP0T HP Universal Instant-dry Gloss Photo Paper-914 mm x 30.5 m (36in x 100ft) In Stock £100.91
CP0T HP Universal Bond Paper-594 mm x 91.4 m In Stock £20.87
CP0T HP Clear Film-914 mm x 22.9 m (36in x 75ft) In Stock £173.23
CP0T HP 771 Light Magenta/Light Cyan Designjet Printhead In Stock £161.77
CP0T HP 771 Photo Black/Light Gray Designjet Printhead In Stock £161.77
CP0T HP 771 Matte Black/Chromatic Red Designjet Printhead In Stock £161.77
CP0T HP 771C 775-ml Matte Black Designjet Ink Cartridge In Stock £199.81
CP0T HP 771C 775-ml Photo Black Designjet Ink Cartridge In Stock £199.81
CP0T HP 771C 775-ml Chromatic Red Designjet Ink Cartridge In Stock £199.81
CP0T HP 771C 775-ml Light Cyan Designjet Ink Cartridge In Stock £199.81
CP0T HP 771C 775-ml Yellow Designjet Ink Cartridge In Stock £199.81
CP0T HP 771C 775-ml Light Magenta Designjet Ink Cartridge In Stock £199.81
CP0T HP 771C 775-ml Magenta Designjet Ink Cartridge In Stock £199.81
CP0T HP 771C 775-ml Light Gray Designjet Ink Cartridge In Stock £199.81
CP0T HP Premium Instant-dry Gloss Photo Paper - 1 Roll In Stock £151.75
CP0T HP Instant Dry Photo Gloss Paper In Stock £69.22
CP0T HP Ink Gloss Photo PPR 235GSM 24X30.5M In Stock £54.67
CP0T HP Premium Matte Poly (36 x 75) 2 Pack In Stock £121.19
CP0T HP Instant Dry Photo Semi-Gloss 24 In Stock £69.22
CP0T HP Premium Instant Dry Gloss Photo (36 in x 100ft) In Stock £124.51
CP0T HP Coated Paper-610 mm x 45.7 m (24in x 150ft) In Stock £28.57
CP0T HP Bright White Inkjet Paper-914 mm x 45.7 m In Stock £25.29
CP0T HP Heavyweight Coated Paper-610 mm x 30.5 m (24in x 100ft) In Stock £34.27
CP0T HP Bright White Inkjet Paper-610 mm x 45.7 m In Stock £16.88
CP0T HP Coated Paper-914 mm x 45.7 m (36in x 150ft) In Stock £40.09
CP0T HP Coated Paper-1067 mm x 45.7 m (42in x 150ft) In Stock £51.20
