HP DesignJet T850 Large-Format Printer - Colour - Ink-Jet
Quicklinx: J4JMWS00 Mfr#: 2Y9H0A#B19
14 In Stock
£2,174.83 ex VAT
£2,609.79 inc VAT
Maximize your team's agility with the world's easiest A4-A0 experience. Simplify multi-size printing with the integrated input tray. Streamline print workflows with HP Click. And meet office and environmental needs with this compact plotter.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
  • Efficient connectivity
    With both Gigabit Ethernet and wireless capabilities, this printer ensures seamless integration into any office environment, allowing for easy setup and continuous operation without the need for complex configurations.
  • High-quality output
    Achieve professional-grade prints with a maximum resolution of 2400 x 1200 DPI for both black and white and color documents, ensuring that every detail is captured with clarity.
  • Versatile media handling
    Designed to accommodate a wide range of media sizes up to 36 inches, this printer is ideal for producing large-format documents such as architectural plans, maps, and presentations with ease.
  • Convenient printing features
    Supports various language simulations including CALS G4, HP GL/2, and more, alongside the ability to print directly from mobile devices, offering flexibility and efficiency in managing print jobs.
  • Robust design
    Equipped with a durable cutter and a total media capacity of 1 roll, this printer is built to handle high-volume printing tasks, making it a reliable tool for busy office settings.
HP DesignJet T850 - large-format printer - colour - ink-jet
Printer Type
36" large-format printer - ink-jet - colour
English, German, French, Italian, Spanish / Europe
Ink Palette Supported (Colours)
4-ink
Max Media Size
Roll (91.4 cm x 91.4 m)
Max Media Size (Custom)
914 mm
Print Speed
Up to 0.42 min/page - draft
Max Resolution (B&W)
2400 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
Cutter
Gigabit LAN, Wi-Fi
AirPrint Enabled
RAM Installed (Max)
1 GB
Language Simulation
HP PCL 3 GUI, HP GL/2, HP RTL, JPEG, CALS G4, URF, TIFF
Total Media Capacity
1 roll
Printer Features
Print from mobile device
Printer Type
Printer
4-ink
Print Speed
Wired
Gigabit LAN, Wi-Fi
AirPrint Enabled
2400 x 1200 dpi
2400 x 1200 dpi
Language Simulation
Cutter
Printer Features
RAM
RAM Installed (Max)
1 GB
Media Handling
Max Media Size
914 mm
Max Printing Length
45.7 m
1 roll
Media Feeders
1 x manual - 1 roll - Roll (91.4 cm x 91.4 m)
Output Trays Capacity
50 sheets
1 x Gigabit LAN - RJ-45
Consumables Included
4 x ink cartridge , 1 x printhead
Ink (1)
J4JM HP Designjet T520 36" Spindle In Stock £46.47
Other bundles (2)
J4JM HP Care Pack Installation Service - Installation / Configuration In Stock £377.00
J4JM HP Care Pack Next Business Day 9x5 Hardware Support - extended service agreement - 3 years - on-site In Stock £311.24
Brand: HP
Price Range Ex VAT: £1500+
