A smart investment for architects, engineers, and construction professionals, this robust, compact 91.4-cm printer easily fits your business. You can reduce time/waste with convenient features. Print conveniently on-the-go with HP Mobile Printing.
SMART – Invest in a robust printer
Robust, compact, and professional – this printer fits your business and gives you space to work.Produces prints 3 times faster than previous HP models – see A1-size prints delivered in 25 seconds.Choose from 40- to 300-ml HP ink cartridges to fit your print volume, large supplies can reduce interventions. -
EASY – Convenient printing helps reduce time, waste
Cut waste by 50% – print at half scale with automatic sheet feeder/tray; cut extra work, waste of wide rolls.The front panel works like a smartphone – easily swipe through the intuitive user interface on the touchscreen.No LAN needed – move this printer any time, any place your Wi-Fi signal can reach with wireless connectivity. -
MOBILE – Easily print from smartphone or tablet
Print from mobile devices in a few simple clicks with HP Mobile Printing – quickly work through revisions.If you're on-the-go, attach your document to an email and send it directly to your printer via ePrint.Use the HP AiO Printer Remote app to access additional print features when printing from a mobile device.The printer creates its own Wi-Fi network for easy connectivity with Wi-Fi Direct.
- HP DesignJet T730 - large-format printer - colour - ink-jet
- Printer Type
- 36" large-format printer - ink-jet - colour
- 48 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, pigment black
- Max Media Size
- Roll (91.4 cm x 45.7 m)
- Min Media Size (Custom)
- 210 mm x 279 mm
- Max Media Size (Custom)
- 914 mm x 45.7 m
- Print Speed
- Up to 1.36 ppm - draft - ANSI D (559 x 864 mm)
- Max Resolution (B&W)
- 2400 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Cutter
- Interface
- Gigabit LAN, Wi-Fi, USB 2.0 host
- AirPrint Enabled
- RAM Installed (Max)
- 1 GB
- Language Simulation
- PCL 3, HP RTL, CALS G4, HP GL/2, TIFF, PDF 1.7, URF
- Media Type
- Coated paper, plain paper, photo paper, tracing paper, glossy photo paper, matt photo paper, bond paper, film, backlit paper, translucent bond paper, heavy-weight coated paper, semi-gloss photo paper, high-gloss photo paper, matte film, vellum paper, polyester film, self-adhesive vinyl, satin photo paper, self-adhesive paper
- Total Media Capacity
- 1 roll
- Printer Features
- Print from mobile device
- System Requirements
- Apple MacOS, Microsoft Windows, Windows 8
- 140.3 cm x 58.3 cm x 115.5 cm
- Printer Type
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 1376 nozzles
- Minimum Ink Droplet Size
- 12.6 pl (black), 6 pl (colour)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 2400 x 1200 dpi
- 2400 x 1200 dpi
- Cutter
- Printer Features
RAM
- 1 GB
Media Handling
- Media Type
- Max Media Size
- 210 mm x 279 mm
- 914 mm x 45.7 m
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), ANSI B (Ledger) (279 x 432 mm), ANSI C (432 x 559 mm), ANSI E (864 x 1118 mm), ANSI D (559 x 864 mm), Roll (91.4 cm x 45.7 m), 210 x 279 mm, 210 x 914 mm, 914 x 1879 mm
- 1 roll
- Media Feeders
- 1 x manual - 1 roll - Roll (91.4 cm x 45.7 m)
- Wi-Fi Direct
- Connections
- 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Included Accessories
- Media bin, stand, spindles
- Consumables Included
- 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (black)
- CSA, VCCI, GOST, CCC, PSB, FCC, IRAM, RoHS, EN 60950-1, KCC, WEEE, ICES, REACH, FSC, LVD, EuP, EMC Class B, PEFC, IPv6 Ready, China RoHS, ACMA
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 35 Watt
- Power Consumption Sleep
- 3.5 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- ENERGY STAR
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission (Operating)
- 48 dBA
- 140.3 cm
- 58.3 cm
- 115.5 cm
- 48 kg
- Width (Shipping)
- 157.8 cm
- Depth (Shipping)
- 57.5 cm
- Height (Shipping)
- 64.6 cm
- Weight (Shipping)
- 70 kg
Ink (6)
HP Universal Bond Paper-914 mm x 45.7 m (36in x 150ft) | In Stock | £15.81 |
HP Designjet T520 36" Spindle | In Stock | £46.47 |
HP 728 - 300ml Yellow Original DesignJet Ink Cartridge | In Stock | £164.26 |
HP 728 - 300ml Magenta Original DesignJet Ink Cartridge | In Stock | £164.26 |
HP 728 - 300ml Cyan Original DesignJet Ink Cartridge | In Stock | £164.26 |
HP Bright White Inkjet Paper-914 mm x 45.7 m | In Stock | £25.29 |
Other bundles (1)
HP Care Pack Installation Service - Installation / Configuration | In Stock | £377.00 |
