HP DesignJet T730 36" Colour InkJet Printer
Quicklinx: BT6QWS00 Mfr#: F9A29A#B19
A smart investment for architects, engineers, and construction professionals, this robust, compact 91.4-cm printer easily fits your business. You can reduce time/waste with convenient features. Print conveniently on-the-go with HP Mobile Printing.
  • SMART – Invest in a robust printer
    Robust, compact, and professional – this printer fits your business and gives you space to work.Produces prints 3 times faster than previous HP models – see A1-size prints delivered in 25 seconds.Choose from 40- to 300-ml HP ink cartridges to fit your print volume, large supplies can reduce interventions.
  • EASY – Convenient printing helps reduce time, waste
    Cut waste by 50% – print at half scale with automatic sheet feeder/tray; cut extra work, waste of wide rolls.The front panel works like a smartphone – easily swipe through the intuitive user interface on the touchscreen.No LAN needed – move this printer any time, any place your Wi-Fi signal can reach with wireless connectivity.
  • MOBILE – Easily print from smartphone or tablet
    Print from mobile devices in a few simple clicks with HP Mobile Printing – quickly work through revisions.If you're on-the-go, attach your document to an email and send it directly to your printer via ePrint.Use the HP AiO Printer Remote app to access additional print features when printing from a mobile device.The printer creates its own Wi-Fi network for easy connectivity with Wi-Fi Direct.
HP DesignJet T730 - large-format printer - colour - ink-jet
Printer Type
36" large-format printer - ink-jet - colour
48 kg
English, German, French, Italian, Spanish / Europe
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, pigment black
Max Media Size
Roll (91.4 cm x 45.7 m)
Min Media Size (Custom)
210 mm x 279 mm
Max Media Size (Custom)
914 mm x 45.7 m
Print Speed
Up to 1.36 ppm - draft - ANSI D (559 x 864 mm)
Max Resolution (B&W)
2400 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
Cutter
Gigabit LAN, Wi-Fi, USB 2.0 host
AirPrint Enabled
RAM Installed (Max)
1 GB
Language Simulation
PCL 3, HP RTL, CALS G4, HP GL/2, TIFF, PDF 1.7, URF
Media Type
Coated paper, plain paper, photo paper, tracing paper, glossy photo paper, matt photo paper, bond paper, film, backlit paper, translucent bond paper, heavy-weight coated paper, semi-gloss photo paper, high-gloss photo paper, matte film, vellum paper, polyester film, self-adhesive vinyl, satin photo paper, self-adhesive paper
Total Media Capacity
1 roll
Printer Features
Apple MacOS, Microsoft Windows, Windows 8
140.3 cm x 58.3 cm x 115.5 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
1376 nozzles
Minimum Ink Droplet Size
12.6 pl (black), 6 pl (colour)
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Print Speed
Wireless
AirPrint Enabled
2400 x 1200 dpi
2400 x 1200 dpi
Language Simulation
Cutter
Printer Features
RAM
RAM Installed (Max)
1 GB
Media Handling
Media Type
Max Media Size
210 mm x 279 mm
914 mm x 45.7 m
Media Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), ANSI B (Ledger) (279 x 432 mm), ANSI C (432 x 559 mm), ANSI E (864 x 1118 mm), ANSI D (559 x 864 mm), Roll (91.4 cm x 45.7 m), 210 x 279 mm, 210 x 914 mm, 914 x 1879 mm
1 roll
Media Feeders
1 x manual - 1 roll - Roll (91.4 cm x 45.7 m)
Security Protocols & Features
Wi-Fi Direct
1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Media bin, stand, spindles
Consumables Included
1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (black)
CSA, VCCI, GOST, CCC, PSB, FCC, IRAM, RoHS, EN 60950-1, KCC, WEEE, ICES, REACH, FSC, LVD, EuP, EMC Class B, PEFC, IPv6 Ready, China RoHS, ACMA
Power supply - internal
Frequency Required
50/60 Hz
35 Watt
Power Consumption Sleep
3.5 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
5 °C
20 - 80%
Sound Emission (Operating)
48 dBA
140.3 cm
58.3 cm
115.5 cm
48 kg
Width (Shipping)
157.8 cm
Depth (Shipping)
57.5 cm
Height (Shipping)
64.6 cm
Weight (Shipping)
70 kg
Ink (4)
BT6Q HP 728 - 300ml Yellow Original DesignJet Ink Cartridge In Stock £175.32
BT6Q HP 728 - 300ml Magenta Original DesignJet Ink Cartridge In Stock £175.32
BT6Q HP 728 - 300ml Cyan Original DesignJet Ink Cartridge In Stock £175.32
BT6Q HP Universal Satin Photo Paper In Stock £86.54
Other bundles (1)
BT6Q HP Care Pack Installation Service - Installation / Configuration In Stock £377.00
