The world's smallest wide-format printer with a built-in stand, is designed to fit your office, budget, and the way you work. Print multi-size projects with ease. Print your A1 plot as fast as 30 seconds. 1 GB memory.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
Extreme simplicity
Print multi-size A3/B and A1/D or A0/E projects automatically, without manually switching the media source. Save time with the world's easiest job submission - send multiple files in one click with HP Click software. Print with confidence you'll get the results you expect with an intuitive driver and true print preview. -
Fits your office and budget
Save space with the world's smallest plotters designed to fit your office, including a built-in stand. Use up to 95% less ink for routine maintenance and get up to 100 extra A1/D pages per month. More sustainable design reduces CO2e up to 7.3tons/year by units sold by using up to 30%recycled plast
- HP DesignJet T630 - large-format printer - colour - ink-jet
- Printer Type
- 36" large-format printer - ink-jet - colour
- 34.7 kg
- Localisation
- English, German, Spanish, French, Italian / Europe
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, pigment black
- Max Media Size
- A0 (841 x 1189 mm), ANSI D (559 x 864 mm), Roll (91.4 cm x 45.7 m)
- Min Media Size (Custom)
- 210 mm x 279 mm
- Max Media Size (Custom)
- 914 mm x 45.7 m
- Print Speed
- Up to 0.5 min/page - black draft - ANSI D (559 x 864 mm) ¦ Up to 0.5 min/page - colour draft - ANSI D (559 x 864 mm) ¦ Up to 0.5 min/page - black draft - A1 (594 x 841 mm) ¦ Up to 0.5 min/page - colour draft - A1 (594 x 841 mm)
- Max Resolution (B&W)
- 2400 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Interface
- USB 2.0, LAN, Wi-Fi
- RAM Installed (Max)
- 1 GB (1 GB)
- Language Simulation
- HP GL/2, HP RTL, CALS G4, JPEG, URF
- Media Type
- Plain paper, photo paper, bond paper, recycled paper, film, glossy paper
- Networking
- Print server
- Printer Features
- Print from mobile device, 6.2 kg max roll weight
- Environmental Standards
- EPEAT Gold
- 1-year warranty
- 131.7 cm x 60.5 cm x 93.2 cm
- Printer Type
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 1376 nozzles
- Minimum Ink Droplet Size
- 12 pl (black), 5.5 pl (colour)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, pigment black)
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- 2400 x 1200 dpi
- 2400 x 1200 dpi
- Printer Features
RAM
- 1 GB / 1 GB (max)
Media Handling
- Media Type
- Max Media Size
- 210 mm x 279 mm
- 914 mm x 45.7 m
- Media Sizes
- A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), ANSI D (559 x 864 mm), Roll (91.4 cm x 45.7 m), A0 (841 x 1189 mm)
- Media Thickness Range
- Up to 0.3 mm
- Media Weight
- 60 g/m² - 280 g/m²
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B ¦ 1 x LAN - RJ-45
- FCC Class B certified, ICES Class B, WEEE, ERP, CSA
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 35 watt
- Power Consumption Stand by
- 0.2 watt
- Power Consumption Sleep
- 2.1 watt
- Software Included
- HP Click, HP DesignJet Utility, HP Support Assistant
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR
- Limited warranty - parts - 1 year
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission (Idle)
- 16 dBA
- Sound Emission (Operating)
- 42 dBA
- 131.7 cm
- 60.5 cm
- 93.2 cm
- 34.7 kg
- Width (Shipping)
- 147 cm
- Depth (Shipping)
- 57.5 cm
- Height (Shipping)
- 59 cm
- Weight (Shipping)
- 55.3 kg
HP Care Pack Installation Service - Installation / Configuration | In Stock | £377.00 |
