Create highly efficient teams with the most compact, quiet MFP that supports collaboration with a smart interface and access to shared folders. Meet deadlines with the fastest print speed and the only automatic print stacking.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
- HP DesignJet T2600dr PostScript MFP - multifunction printer - colour
- 36" multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 6-ink
- Max Printing Speed
- Up to 0.32 min/page (mono) / up to 0.32 min/page (colour)
- Max Printing Resolution
- Up to 2400 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
- Scanning
- 600 dpi
- Original Size
- 210 x 297 mm (min) - 914 x 8000 mm, 610 x 15000 mm (max)
- Media Size
- 210 x 279 mm (min) - Roll (91.4 cm x 91.4 m), 914 x 1219 mm (max)
- Media Type
- Coated paper, heavy-weight matte paper, bond paper, glossy photo paper, satin photo paper
- Standard Media Capacity
- 2 rolls
- Stacker
- Included
- Connection Availability
- Interface
- USB, Gigabit LAN
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, Hard Disk Drive Encryption, save to network folder, automatic cutter, Trusted Platform Module (TPM), print from e-mail, scan to network folder
- Power
- AC 120/230 V (50/60Hz)
- 139 cm x 76 cm x 124 cm
- 109 kg
- Environmental Standards
- ENERGY STAR Qualified
- 2-year warranty
- Ink-jet - colour
- Interface
- USB, Gigabit LAN
- AirPrint Enabled
- Localisation
- Standard Memory
- 128 GB
- Hard Disk Drive
- 500 GB
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 6 cartridges (1 each: cyan, magenta, yellow, grey, photo black, matte black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, photo black, pigment matte black, grey
- 6-ink
- Printer Drivers / Emulations
- PostScript 3, PDF 1.7, HPGL/2, HP-RTL, CALS G4, JPEG
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 dpi
Document & Media Handling
- Min Original Size
- 210 x 297 mm
- Max Original Size
- Min Media Size
- 210 x 279 mm
- Max Media Size
- Other
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 328 g/m²
- Media Thickness Range
- Up to 0.5 mm
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), ANSI B (Ledger) (279 x 432 mm), ANSI C (432 x 559 mm), ANSI E (864 x 1118 mm), ANSI D (559 x 864 mm), Roll (91.4 cm x 91.4 m), 914 x 1219 mm, 210 x 279 mm, 210 x 914 mm
- 2 rolls
- Input tray - 2 rolls - Roll (91.4 cm x 91 m) weight: 60 g/m² - 328 g/m²
- Speed Details
- Printing: 19.3 sec (A1) - B/W draft , Printing: 19.3 sec (A1) - colour draft , Scanning: up to 76.2 mm/sec - colour (200 dpi) , Scanning: up to 254 mm/sec - B/W (200 dpi) , Copying: up to 152.4 mm/sec - colour , Copying: up to 254 mm/sec - B/W
Finishing Equipment
- Stacker
- Included
- 1 x Gigabit LAN - RJ-45 , 1 x USB
- Kerberos, LDAP, SSL, Apple Bonjour, LEAP, SMB authentication, TLS, IPsec, 802.1x, EAP-TLS, PEAP, SNMP 3
- Software Included
- HP Web Jetadmin, HP Smart App, HP JetAdvantage Security Manager
- Voltage Required
- 120 Watt
- Power Consumption Standby
- 36 Watt
- Power Consumption Sleep
- 10 Watt
- Included Accessories
- Stand, media bin, 15.6" touchscreen, 2 x spindles
- FCC Class A certified, CSA, EMC, PSB, IRAM, RoHS, EN 60950-1, WEEE, REACH, ICES Class A, KCC Class A, ERP, VCCI Class A, CCC Class A, BIS, ACMA, UA, RSM, Ukraine, EU Low Voltage Directive, EAC (Belarus, Kazakhstan, Russia), NYCE
- ENERGY STAR Certified
- Limited warranty - 2 years
- 139 cm
- 76 cm
- 124 cm
- 109 kg
- Shipping Width
- 147.7 cm
- Shipping Depth
- 76.7 cm
- Shipping Height
- 80 cm
- Shipping Weight
- 142 kg
- Sound Emission
- 32 dBA (idle) / 42 dBA (operating)
- 5 °C
- 35 °C
- 20 - 80% RH
HP 727 Designjet Printhead | In Stock | £265.77 |
