HP DesignJet T2600dr PostScript 36" Colour InkJet Large Format Multifunction Printer
Quicklinx: FMJFWS00 Mfr#: 3EK15A#B19
Create highly efficient teams with the most compact, quiet MFP that supports collaboration with a smart interface and access to shared folders. Meet deadlines with the fastest print speed and the only automatic print stacking.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
HP DesignJet T2600dr PostScript MFP - multifunction printer - colour
36" multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 6-ink
Max Printing Speed
Up to 0.32 min/page (mono) / up to 0.32 min/page (colour)
Max Printing Resolution
Up to 2400 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
Scanning
600 dpi
Original Size
210 x 297 mm (min) - 914 x 8000 mm, 610 x 15000 mm (max)
Media Size
210 x 279 mm (min) - Roll (91.4 cm x 91.4 m), 914 x 1219 mm (max)
Media Type
Coated paper, heavy-weight matte paper, bond paper, glossy photo paper, satin photo paper
Standard Media Capacity
2 rolls
Stacker
Included
Connection Availability
Gigabit LAN, USB
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to network folder, automatic cutter, Trusted Platform Module (TPM), print from e-mail, scan to network folder, scan to e-mail, save to USB flash drive, Hard Disk Drive Encryption
AC 120/230 V (50/60Hz)
139 cm x 76 cm x 124 cm
109 kg
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Ink-jet - colour
Gigabit LAN, USB
AirPrint Enabled
Standard Memory
128 GB
Hard Disk Drive
500 GB
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
6 cartridges (1 each: cyan, magenta, yellow, grey, photo black, matte black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, photo black, pigment matte black, grey
6-ink
Printer Drivers / Emulations
PostScript 3, PDF 1.7, HPGL/2, HP-RTL, CALS G4, JPEG
Scanning
Scan Element
CIS
Optical Resolution
600 dpi
Document & Media Handling
Min Original Size
210 x 297 mm
Max Original Size
Min Media Size
210 x 279 mm
Max Media Size
Other
Min Media Weight
60 g/m²
Max Media Weight
328 g/m²
Media Thickness Range
Up to 0.5 mm
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), ANSI B (Ledger) (279 x 432 mm), ANSI C (432 x 559 mm), ANSI E (864 x 1118 mm), ANSI D (559 x 864 mm), Roll (91.4 cm x 91.4 m), 914 x 1219 mm, 210 x 279 mm, 210 x 914 mm
2 rolls
Input tray - 2 rolls - Roll (91.4 cm x 91 m) weight: 60 g/m² - 328 g/m²
Speed Details
Printing: 19.3 sec (A1) - B/W draft , Printing: 19.3 sec (A1) - colour draft , Scanning: up to 76.2 mm/sec - colour (200 dpi) , Scanning: up to 254 mm/sec - B/W (200 dpi) , Copying: up to 152.4 mm/sec - colour , Copying: up to 254 mm/sec - B/W
Finishing Equipment
Stacker
Included
1 x Gigabit LAN - RJ-45 , 1 x USB
Security Protocols & Features
Kerberos, LDAP, SSL, Apple Bonjour, LEAP, SMB authentication, TLS, IPsec, 802.1x, EAP-TLS, PEAP, SNMP 3
Software Included
HP Web Jetadmin, HP Smart App, HP JetAdvantage Security Manager
120 Watt
Power Consumption Standby
36 Watt
Power Consumption Sleep
10 Watt
Stand, media bin, 15.6" touchscreen, 2 x spindles
EMC, RoHS, EN 60950-1, WEEE, REACH, ERP, EU Low Voltage Directive, FCC Class A certified, ICES Class A, ACMA, RSM, CCC Class A, VCCI Class A, KCC Class A, EAC (Belarus, Kazakhstan, Russia), PSB, Ukraine, UA, IRAM, NYCE, BIS, CSA
ENERGY STAR Certified
139 cm
76 cm
124 cm
109 kg
Shipping Width
147.7 cm
Shipping Depth
76.7 cm
Shipping Height
80 cm
Shipping Weight
142 kg
Sound Emission
32 dBA (idle) / 42 dBA (operating)
5 °C
35 °C
20 - 80% RH
FMJF HP 727 Designjet Printhead In Stock £303.99
