HP DesignJet T250 Large-Format Printer
Quicklinx: H3TTWS00 Mfr#: 5HB06A#B19
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wireless, Wired
Technology: Ink-jet
£742.54 ex VAT
£891.04 inc VAT
Designed to fit your office, budget, and the way you work, the world's smallest plotters provide outstanding simplicity. Send multiple files in just one click. Print your A1 plot as fast as 30 seconds. 500 MB memory.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
  • Efficient connectivity
    The HP DesignJet T250 offers both wired and wireless connectivity options, allowing users to print effortlessly from various devices, including mobile devices, without the hassle of cords.
  • Versatile media support
    This large-format printer accommodates multiple media types, including plain paper, photo paper, and technical paper, giving users the flexibility they need for various printing tasks.
  • High-quality output
    With a maximum resolution of 2400 x 1200 DPI, the printer delivers color accuracy and detail, making it suitable for high-quality graphics and professional presentations.
  • Eco-friendly operation
    This printer is EPEAT Gold registered and ENERGY STAR certified, ensuring reduced environmental impact while delivering efficient performance and low power consumption.
  • Fast printing performance
    Capable of producing prints in just 0.5 minutes per page, the HP DesignJet T250 enhances productivity, making it ideal for busy work environments.
HP DesignJet T250 - large-format printer - colour - ink-jet
Printer Type
24" large-format printer - ink-jet - colour
21.5 kg
English, German, Spanish, French, Italian / Europe
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, pigment black
Max Media Size
A1 (594 x 841 mm), ANSI D (559 x 864 mm)
Min Media Size (Custom)
210 mm x 279 mm
Max Media Size (Custom)
610 mm x 45.7 m
Print Speed
Up to 0.5 min/page - black draft - ANSI D (559 x 864 mm) , Up to 0.5 min/page - colour draft - ANSI D (559 x 864 mm) , Up to 0.5 min/page - black draft - A1 (594 x 841 mm) , Up to 0.5 min/page - colour draft - A1 (594 x 841 mm)
Max Resolution (B&W)
2400 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
USB 2.0, LAN, Wi-Fi
RAM Installed (Max)
512 MB (512 MB)
Language Simulation
JPEG, URF
Media Type
Bond paper, film, technical paper, plain paper, photo paper, glossy paper, self-adhesive paper, semi-gloss paper
Print server
Printer Features
Print from mobile device, 4.1 kg max roll weight
Environmental Standards
EPEAT Gold
101.3 cm x 44 cm x 28.5 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
1376 nozzles
Minimum Ink Droplet Size
12 pl (black), 5.5 pl (colour)
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, pigment black)
Print Speed
Wireless
USB 2.0, LAN, Wi-Fi
2400 x 1200 dpi
2400 x 1200 dpi
Language Simulation
JPEG, URF
Printer Features
RAM
RAM Installed (Max)
512 MB / 512 MB (max)
Media Handling
Media Type
Max Media Size
210 mm x 279 mm
610 mm x 45.7 m
Media Sizes
A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), ANSI A (Letter) (216 x 279 mm), ANSI B (Ledger) (279 x 432 mm), ANSI C (432 x 559 mm), ANSI D (559 x 864 mm), Roll (61 cm x 45.7 m)
Media Thickness Range
Up to 0.3 mm
Media Weight
60 g/m² - 280 g/m²
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
WEEE, REACH, ERP
Power supply - internal
Frequency Required
50/60 Hz
35 Watt
Power Consumption Stand by
0.2 Watt
Power Consumption Sleep
2.1 Watt
Software Included
HP Click, HP DesignJet Utility, HP Support Assistant
EPEAT Compliant
EPEAT Gold
ENERGY STAR
5 °C
20 - 80%
Sound Emission (Idle)
16 dBA
Sound Emission (Operating)
42 dBA
101.3 cm
44 cm
28.5 cm
21.5 kg
Width (Shipping)
115.5 cm
Depth (Shipping)
57.5 cm
Height (Shipping)
40.5 cm
Weight (Shipping)
28 kg
H3TT HP Care Pack Installation Service - Installation / Configuration In Stock £377.00
H3TT HP Printer Stand for DesignJet T210, T230, T250, T610 (24"), T620 (24"), T630 (24"), T650 (24") In Stock £188.02
Type: Printer
Output Type: Colour
Wireless Capability: Wired
Technology: Ink-jet
Max Print Speed: 21ppm
Max Paper Size: ANSI D (559 x 864 mm)
Max Paper Size: A1 (594 x 841 mm)
Brand: HP
Price Range Ex VAT: £500 - £750
