Designed to fit your office, budget, and the way you work, the world's smallest plotters provide outstanding simplicity. Send multiple files in just one click. Print your A1 plot as fast as 30 seconds. 500 MB memory.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
Efficient connectivity
The HP DesignJet T250 offers both wired and wireless connectivity options, allowing users to print effortlessly from various devices, including mobile devices, without the hassle of cords. -
Versatile media support
This large-format printer accommodates multiple media types, including plain paper, photo paper, and technical paper, giving users the flexibility they need for various printing tasks. -
High-quality output
With a maximum resolution of 2400 x 1200 DPI, the printer delivers color accuracy and detail, making it suitable for high-quality graphics and professional presentations. -
Eco-friendly operation
This printer is EPEAT Gold registered and ENERGY STAR certified, ensuring reduced environmental impact while delivering efficient performance and low power consumption. -
Fast printing performance
Capable of producing prints in just 0.5 minutes per page, the HP DesignJet T250 enhances productivity, making it ideal for busy work environments.
- HP DesignJet T250 - large-format printer - colour - ink-jet
- Printer Type
- 24" large-format printer - ink-jet - colour
- 21.5 kg
- Localisation
- English, German, Spanish, French, Italian / Europe
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, pigment black
- Max Media Size
- A1 (594 x 841 mm), ANSI D (559 x 864 mm)
- Min Media Size (Custom)
- 210 mm x 279 mm
- Max Media Size (Custom)
- 610 mm x 45.7 m
- Print Speed
- Up to 0.5 min/page - black draft - ANSI D (559 x 864 mm) , Up to 0.5 min/page - colour draft - ANSI D (559 x 864 mm) , Up to 0.5 min/page - black draft - A1 (594 x 841 mm) , Up to 0.5 min/page - colour draft - A1 (594 x 841 mm)
- Max Resolution (B&W)
- 2400 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Interface
- USB 2.0, LAN, Wi-Fi
- RAM Installed (Max)
- 512 MB (512 MB)
- Language Simulation
- JPEG, URF
- Media Type
- Bond paper, film, technical paper, plain paper, photo paper, glossy paper, self-adhesive paper, semi-gloss paper
- Networking
- Print server
- Printer Features
- Print from mobile device, 4.1 kg max roll weight
- Environmental Standards
- EPEAT Gold
- 2-year warranty
- 101.3 cm x 44 cm x 28.5 cm
- Printer Type
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 1376 nozzles
- Minimum Ink Droplet Size
- 12 pl (black), 5.5 pl (colour)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, pigment black)
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- 2400 x 1200 dpi
- 2400 x 1200 dpi
- JPEG, URF
- Printer Features
RAM
- 512 MB / 512 MB (max)
Media Handling
- Media Type
- Max Media Size
- 210 mm x 279 mm
- 610 mm x 45.7 m
- Media Sizes
- A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), ANSI A (Letter) (216 x 279 mm), ANSI B (Ledger) (279 x 432 mm), ANSI C (432 x 559 mm), ANSI D (559 x 864 mm), Roll (61 cm x 45.7 m)
- Media Thickness Range
- Up to 0.3 mm
- Media Weight
- 60 g/m² - 280 g/m²
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- WEEE, REACH, ERP
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 35 Watt
- Power Consumption Stand by
- 0.2 Watt
- Power Consumption Sleep
- 2.1 Watt
- Software Included
- HP Click, HP DesignJet Utility, HP Support Assistant
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR
- Limited warranty - 2 years
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission (Idle)
- 16 dBA
- Sound Emission (Operating)
- 42 dBA
- 101.3 cm
- 44 cm
- 28.5 cm
- 21.5 kg
- Width (Shipping)
- 115.5 cm
- Depth (Shipping)
- 57.5 cm
- Height (Shipping)
- 40.5 cm
- Weight (Shipping)
- 28 kg
HP Designjet T120/T520 24" Spindle | In Stock | £46.47 |
HP Care Pack Installation Service - Installation / Configuration | In Stock | £377.00 |
HP Printer Stand for DesignJet T210, T230, T250, T610 (24"), T620 (24"), T630 (24"), T650 (24") | In Stock | £188.02 |
