Designed to fit your office, budget, and the way you work, the world's smallest plotters provide outstanding simplicity. Send multiple files in just one click. Print your A1 plot as fast as 35 seconds. 500 MB memory.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
Extreme simplicity
Print with confidence you'll get the results you expect with an intuitive driver and true print preview. You can also send multiple files in one click with HP Click software. -
Fits your office and budget
These compact plotters improve efficiency to meet space limitations and budgetary requirements. Not just a compact plotter, it's also made from up to 30% recycled plastic. -
Fits the way you work
With the HP Smart app you can print virtually from anywhere with your smartphone or tablet. Stand by anything other than a printer.
- HP DesignJet T230 - large-format printer - colour - ink-jet
- Printer Type
- 24" large-format printer - ink-jet - colour
- 21.5 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, pigment black
- Max Media Size
- A1 (594 x 841 mm), ANSI D (559 x 864 mm)
- Min Media Size (Custom)
- 210 mm x 279 mm
- Max Media Size (Custom)
- 610 mm x 45.7 m
- Print Speed
- Up to 0.58 min/page - black draft - ANSI D (559 x 864 mm) ¦ Up to 0.58 min/page - colour draft - ANSI D (559 x 864 mm) ¦ Up to 0.58 min/page - black draft - A1 (594 x 841 mm) ¦ Up to 0.58 min/page - colour draft - A1 (594 x 841 mm)
- Max Resolution (B&W)
- 2400 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Interface
- USB 2.0, LAN, Wi-Fi
- RAM Installed (Max)
- 512 MB (512 MB)
- Language Simulation
- URF, JPEG
- Media Type
- Plain paper, photo paper, bond paper, film, glossy paper, semi-gloss paper, technical paper, self-adhesive paper
- Networking
- Print server
- Printer Features
- Print from mobile device, 4.1 kg max roll weight
- Environmental Standards
- EPEAT Gold
- 1-year warranty
- 101.3 cm x 44 cm x 28.5 cm
- Printer Type
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 1376 nozzles
- Minimum Ink Droplet Size
- 12 pl (black), 5.5 pl (colour)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, pigment black)
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- 2400 x 1200 dpi
- 2400 x 1200 dpi
- URF, JPEG
- Printer Features
RAM
- 512 MB / 512 MB (max)
Media Handling
- Media Type
- Max Media Size
- 210 mm x 279 mm
- 610 mm x 45.7 m
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), ANSI B (Ledger) (279 x 432 mm), ANSI C (432 x 559 mm), ANSI D (559 x 864 mm)
- Media Thickness Range
- Up to 0.3 mm
- Media Weight
- 60 g/m² - 280 g/m²
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B ¦ 1 x LAN - RJ-45
- EMC, WEEE, REACH, ERP, EU RoHS, RED, EAEU RoHS
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 35 Watt
- Power Consumption Stand by
- 0.2 Watt
- Power Consumption Sleep
- 2.1 Watt
- Software Included
- HP Support Assistant, HP Click, HP DesignJet Utility
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR
- Limited warranty - 1 year
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission (Idle)
- 16 dBA
- Sound Emission (Operating)
- 42 dBA
- 101.3 cm
- 44 cm
- 28.5 cm
- 21.5 kg
- Width (Shipping)
- 115.5 cm
- Depth (Shipping)
- 57.5 cm
- Height (Shipping)
- 40.5 cm
- Weight (Shipping)
- 28 kg
