HP DesignJet T230 Large-Format Printer
Quicklinx: GTSKWS00 Mfr#: 5HB07A#B19
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired, Wireless
Technology: Ink-jet
£670.48 ex VAT
£804.57 inc VAT
Designed to fit your office, budget, and the way you work, the world's smallest plotters provide outstanding simplicity. Send multiple files in just one click. Print your A1 plot as fast as 35 seconds. 500 MB memory.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
  • Extreme simplicity
    Print with confidence you'll get the results you expect with an intuitive driver and true print preview. You can also send multiple files in one click with HP Click software.
  • Fits your office and budget
    These compact plotters improve efficiency to meet space limitations and budgetary requirements. Not just a compact plotter, it's also made from up to 30% recycled plastic.
  • Fits the way you work
    With the HP Smart app you can print virtually from anywhere with your smartphone or tablet. Stand by anything other than a printer.
HP DesignJet T230 - large-format printer - colour - ink-jet
Printer Type
24" large-format printer - ink-jet - colour
21.5 kg
English, German, French, Italian, Spanish / Europe
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, pigment black
Max Media Size
A1 (594 x 841 mm), ANSI D (559 x 864 mm)
Min Media Size (Custom)
210 mm x 279 mm
Max Media Size (Custom)
610 mm x 45.7 m
Print Speed
Up to 0.58 min/page - black draft - ANSI D (559 x 864 mm) , Up to 0.58 min/page - colour draft - ANSI D (559 x 864 mm) , Up to 0.58 min/page - black draft - A1 (594 x 841 mm) , Up to 0.58 min/page - colour draft - A1 (594 x 841 mm)
Max Resolution (B&W)
2400 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
USB 2.0, LAN, Wi-Fi
RAM Installed (Max)
512 MB (512 MB)
Language Simulation
URF, JPEG
Media Type
Plain paper, photo paper, bond paper, film, glossy paper, semi-gloss paper, technical paper, self-adhesive paper
Print server
Printer Features
Print from mobile device, 4.1 kg max roll weight
Environmental Standards
EPEAT Gold
1-year warranty
101.3 cm x 44 cm x 28.5 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
1376 nozzles
Minimum Ink Droplet Size
12 pl (black), 5.5 pl (colour)
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, pigment black)
Print Speed
Wireless
USB 2.0, LAN, Wi-Fi
2400 x 1200 dpi
2400 x 1200 dpi
Language Simulation
URF, JPEG
Printer Features
RAM
RAM Installed (Max)
512 MB / 512 MB (max)
Media Handling
Media Type
Max Media Size
210 mm x 279 mm
610 mm x 45.7 m
Media Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), ANSI B (Ledger) (279 x 432 mm), ANSI C (432 x 559 mm), ANSI D (559 x 864 mm)
Media Thickness Range
Up to 0.3 mm
Media Weight
60 g/m² - 280 g/m²
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
EMC, WEEE, REACH, ERP, EU RoHS, RED, EAEU RoHS
Power supply - internal
Frequency Required
50/60 Hz
35 Watt
Power Consumption Stand by
0.2 Watt
Power Consumption Sleep
2.1 Watt
Software Included
HP Support Assistant, HP Click, HP DesignJet Utility
EPEAT Compliant
EPEAT Gold
ENERGY STAR
Limited warranty - 1 year
5 °C
20 - 80%
Sound Emission (Idle)
16 dBA
Sound Emission (Operating)
42 dBA
101.3 cm
44 cm
28.5 cm
21.5 kg
Width (Shipping)
115.5 cm
Depth (Shipping)
57.5 cm
Height (Shipping)
40.5 cm
Weight (Shipping)
28 kg
GTSK HP Care Pack Installation Service - Installation / Configuration In Stock £377.00
GTSK HP Printer Stand for DesignJet T210, T230, T250, T610 (24"), T620 (24"), T630 (24"), T650 (24") In Stock £188.02
GTSK HP - Roll cover - for DesignJet T210, T230, T250, T610 (24"), T620, T650 (24") In Stock £80.23
GTSK HP Automatic Sheet Feeder - Media tray/feeder for DesignJet T210, T230, T250, T610, T620, T630, T650 In Stock £112.65
Type: Printer
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
Max Print Speed: [N/A]
Max Paper Size: ANSI D (559 x 864 mm)
Max Paper Size: A1 (594 x 841 mm)
Brand: HP
Price Range Ex VAT: £500 - £750
