Confidently take CAD, GIS colour reproduction to the next level with a 44-in (1118 mm) printer that delivers powerful security features, high productivity on even the most complex files with the Adobe PDF driver, and bright and precise colours.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
- HP DesignJet T1700 - large-format printer - colour - ink-jet
- Printer Type
- 44" large-format printer - ink-jet - colour
- 72 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 6-ink - cyan, magenta, yellow, photo black, pigment matte black, grey
- Max Media Size
- 1118 x 1676 mm
- Min Media Size (Custom)
- 210 mm x 279 mm
- Max Media Size (Custom)
- 1118 mm x 1676 mm
- Print Speed
- Up to 0.55 min/page - line drawing B/W - A1 (594 x 841 mm) , Up to 0.55 min/page - line drawing B/W - ANSI D (559 x 864 mm)
- Max Resolution (B&W)
- 2400 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Cutter
- Interface
- Gigabit LAN, USB host
- RAM Installed (Max)
- 4 GB
- Hard Drive
- 500 GB
- Language Simulation
- CALS G4, HP GL/2, TIFF, URF, JPEG
- Media Type
- Plain paper, vinyl, bond paper, film, backlit paper, translucent bond paper, photographic paper, glossy paper, matte paper, semi-gloss paper
- Networking
- Print server
- Printer Features
- Print from mobile device, 128GB virtual memory
- Environmental Standards
- EPEAT Bronze
- 2-year warranty
- 180.2 cm x 69.5 cm x 99.8 cm
- Printer Type
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 6 x 2112 nozzles
- Minimum Ink Droplet Size
- 6 pl
- Ink Cartridge Configuration
- 6 cartridges (1 each: cyan, magenta, yellow, grey, photo black, matte black)
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- 2400 x 1200 dpi
- 2400 x 1200 dpi
- Cutter
- Printer Features
RAM
- 4 GB
Storage
- Hard Drive
- 500 GB
Media Handling
- Media Type
- Max Media Size
- 1118 x 1676 mm
- 210 mm x 279 mm
- 1118 mm x 1676 mm
- Media Sizes
- A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), 210 x 279 mm, 1118 x 1676 mm
- Media Thickness Range
- Up to 0.8 mm
- Media Weight
- 60 g/m² - 328 g/m²
- Media Feeders
- 1 x manual - 1 roll - 1118 x 1676 mm weight: 60 g/m² - 328 g/m²
- Networking
- Print server
- Remote Management Protocol
- HTTPS
- TLS, IPsec, 802.1x
- Connections
- 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Self-Encrypting Drive (SED) support, Adobe PDF Print Engine
- CSA, VCCI, SABS, CCC, EMC, PSB, FCC, IRAM, RoHS, EN 60950-1, KCC, WEEE, ICES, REACH, LVD, EAC, BIS, ACMA, RSM
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 100 Watt
- Power Consumption Sleep
- 6.5 Watt
- Software Included
- Drivers & Utilities, HP Web JetAdmin, HP Embedded Web Server, HP Click, HP JetAdvantage Security Manager, HP Partner Link, HP MPS
- EPEAT Compliant
- EPEAT Bronze
- ENERGY STAR
- Limited warranty - parts - 2 years
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission (Idle)
- 15 dBA
- Sound Emission (Operating)
- 45 dBA
- 180.2 cm
- 69.5 cm
- 99.8 cm
- 72 kg
- Width (Shipping)
- 195.5 cm
- Depth (Shipping)
- 77 cm
- Height (Shipping)
- 71 cm
- Weight (Shipping)
- 126 kg
